Discuss
side by side freezer wont turn off, frosts up
 in
Refrigerator & Freezer Repair
The 17 year old refrigerator, freezer runs most of the time and frosts up the coils to the point that
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » side by side freezer wont turn off, frosts up
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-28-2011, 10:32 AM
Junior Member
blfoust is on a distinguished road
Default side by side freezer wont turn off, frosts up
Model Number: SRD225W   Brand: Amana   Age: More than 10 years
The 17 year old refrigerator, freezer runs most of the time and frosts up the coils to the point that the freezer and frig get warm. We defrosted manually, turned on again, it now will turn off randomly but most of the time it is running. Freezer gets to 0 deg and fridge to 20 deg F. I can manually turn it off and then turn it back on and it will stay off for a little while but turns back on again and continues to run. Both sides are set at a low setting 3/7. I have read the posts and see that this information is recommended for one individual with a different model. Should this be the process we follow also?
Replacement parts for AMANA SZI20MW Ref - SXS/I&W | AppliancePartsPros.com
If the evaporator coils are heavily iced/frosted up, then you probably have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 28 in Section 7) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 26 in Section 2) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 24 in Section 2 ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Other things to check are:
If the evaporator coils only have frost in one area (usually where the freon enters them) or is very blotchy you may have a low freon problem.
Are the condenser coils under the unit clean?
Is the condenser/compressor fan running?
Is the evaporator fan running?
Related Models
Amana SRD22S3E REF - SXS/I&W
Amana SRD22S3L REF - SXS/I&W
Amana SRD22S3W REF - SXS/I&W
Amana SRD22S5E REF - SXS/I&W
Amana SRD22S5L REF - SXS/I&W
Amana SRD22S5W REF - SXS/I&W
Amana SRD22TPE REF - SXS/I&W
Amana SRD22TPSE REF - SXS/I&W
Amana SRD22TPW REF - SXS/I&W
Amana SRD22VPE REF - SXS/I&W
Amana SRD22VPL REF - SXS/I&W
Amana SRD22VPSE REF - SXS/I&W
Amana SRD22VPW REF - SXS/I&W
Amana SRD23V Ref - SXS/I&W
Amana SRD23VE REF - SXS/I&W
Amana SRD23VL REF - SXS/I&W
Amana SRD23VP Ref - SXS/I&W
Amana SRD23VPE REF - SXS/I&W
Amana SRD23VPSE REF - SXS/I&W
Amana SRD23VW REF - SXS/I&W
Amana SRD25S3E REF - SXS/I&W
Amana SRD25S3L REF - SXS/I&W
Amana SRD25S3W REF - SXS/I&W
Amana SRD25S5E REF - SXS/I&W
Amana SRD25S5L REF - SXS/I&W
Amana SRD25S5W REF - SXS/I&W
Amana SRD25TPE REF - SXS/I&W
Amana SRD25TPL REF - SXS/I&W
Amana SRD25TPSE REF - SXS/I&W
Amana SRD25TPW REF - SXS/I&W
Amana SRD25VPE REF - SXS/I&W
Amana SRD25VPL REF - SXS/I&W
Amana SRD25VPSE REF - SXS/I&W
Amana SRD25VPW REF - SXS/I&W
Amana SRD26VE REF - SXS/I&W
Amana SRD26VL REF - SXS/I&W
Amana SRD26VPE REF - SXS/I&W
Amana SRD26VPSE REF - SXS/I&W
Amana SRD26VW REF - SXS/I&W
Amana SRD27S2E REF - SXS/I&W
Amana SRD27S2L REF - SXS/I&W
Amana SRD27S2W REF - SXS/I&W
Amana SRD27S4E REF - SXS/I&W
Amana SRD27S4L REF - SXS/I&W
Amana SRD27S4W REF - SXS/I&W
Amana SRD27TPE REF - SXS/I&W
Amana SRD27TPSE REF - SXS/I&W
Amana SRD27TPW REF - SXS/I&W
Amana SRD325S5E REF - SXS/I&W
Amana SRD325S5L REF - SXS/I&W
Amana SRD325S5W REF - SXS/I&W
Amana SRD327S3L REF - SXS/I&W
Amana SRD327S3W REF - SXS/I&W
Amana SRD520SE REF - SXS/I&W
Amana SRD520SL REF - SXS/I&W
Amana SRD520SW REF - SXS/I&W
Amana SRD520TE REF - SXS/I&W
Amana SRD520TW REF - SXS/I&W
Amana SRD522SW REF - SXS/I&W
Amana SRD522TE REF - SXS/I&W
Amana SRD522TW REF - SXS/I&W
Amana SRD522VE REF - SXS/I&W
Amana SRD522VW REF - SXS/I&W
Amana SRD526SL REF - SXS/I&W
Amana SRD526SW REF - SXS/I&W
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Side by side comptessor kiks off and wont restart ZU4LIFE Refrigerator & Freezer Repair 4 03-09-2011 02:08 AM
side by side fridg wont hold temp freezes everything RJONES041 Refrigerator & Freezer Repair 0 01-05-2011 07:58 PM
GE Profile Arctica Side by Side is staying at around 20 F in the Freezer side Lakesun Refrigerator & Freezer Repair 0 11-25-2010 10:22 AM
Side by Side refrigerator/freezer side not cool baq66 Refrigerator & Freezer Repair 5 08-03-2009 09:07 AM
