Discuss
Whirlpool Ice Maker Problems
 in
Refrigerator & Freezer Repair
I have a Whirlpool side by side, model # ED 22PE that has just quit making ice. I have checked
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Ice Maker Problems
  #1 (permalink)
Old 11-10-2007, 07:58 AM
Junior Member
ponyboy is on a distinguished road
Question Whirlpool Ice Maker Problems
Model Number: ED22PE   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool side by side, model # ED 22PE that has just quit making ice. I have checked the lines to makes sure there are no frozen or broken lines.
About a week before it quit it started making random "hollow" ice cubes. Some of them would be solid, some hollow.
Nothing happens when you flip the coat hangar wire.
Bad water inlet valve? Or maybe mold thermometer? Or solenoid? (suggestions from local appliance guy I called)
I am quite new to appliance repair, was hoping I could get some help. I called locally and was told to check if the ice maker would "go into harvest mode" (?). What is harvest mode and how to I make it do that?
Thanks for the help from a dummy that misses his crushed ice.
Pony
Ads By Google
Related Models
Whirlpool ED22PEXHB00
Whirlpool ED22PEXHB01
Whirlpool ED22PEXHB02
Whirlpool ED22PEXHB03
Whirlpool ED22PEXHT00
Whirlpool ED22PEXHT01
Whirlpool ED22PEXHT02
Whirlpool ED22PEXHT03
Whirlpool ED22PEXHW00
Whirlpool ED22PEXHW01
Whirlpool ED22PEXHW02
Whirlpool ED22PEXHW03
Whirlpool ED22PFXBN00
Whirlpool ED22PFXBW00
Whirlpool ED22PKXBN00
Whirlpool ED22PKXBN10
Whirlpool ED22PKXBW00
Whirlpool ED22PKXBW10
Whirlpool ED22PKXDN00
Whirlpool ED22PKXDN01
Whirlpool ED22PKXDN03
Whirlpool ED22PKXDW00
Whirlpool ED22PKXDW01
Whirlpool ED22PKXDW03
Whirlpool ED22PKXFN00
Whirlpool ED22PKXFW00
Whirlpool ED22PMXSW00
Whirlpool ED22PMXSW10
Whirlpool ED22PMXSW11
Whirlpool ED22PQXDN00
Whirlpool ED22PQXDN01
Whirlpool ED22PQXDN02
Whirlpool ED22PQXDN04
Whirlpool ED22PQXDN05
Whirlpool ED22PQXDW00
Whirlpool ED22PQXDW01
Whirlpool ED22PQXDW02
Whirlpool ED22PQXDW04
Whirlpool ED22PQXDW05
Whirlpool ED22PQXFN00
Whirlpool ED22PQXFN01
Whirlpool ED22PQXFW00
Whirlpool ED22PQXFW01
Whirlpool ED22PQXYN00
Whirlpool ED22PQXYW00
Whirlpool ED22PRXRWR0
Whirlpool ED22PRXRWR1
Whirlpool ED22PSQDN00
Whirlpool ED22PSQDN01
Whirlpool ED22PSQDW00
Whirlpool ED22PSQDW01
Whirlpool ED22PSXDN00
Whirlpool ED22PSXDN01
Whirlpool ED22PSXDN02
Whirlpool ED22PSXDW00
Whirlpool ED22PSXDW01
Whirlpool ED22PSXDW02
Whirlpool ED22PWXAN00
Whirlpool ED22PWXAN10
Whirlpool ED22PWXAN11
Whirlpool ED22PWXAW00
Whirlpool ED22PWXAW10
Whirlpool ED22PWXAW11
Whirlpool ED22PWXBN00
Whirlpool ED22PWXBN01
Whirlpool ED22PWXBW00
Whirlpool ED22PWXBW01
Whirlpool ED22PWXDN00
Whirlpool ED22PWXDN01
Whirlpool ED22PWXDW00
Whirlpool ED22PWXDW01
Whirlpool ED22PWXWN10
Whirlpool ED22PWXWW10
Whirlpool ED22PWXXN00
Whirlpool ED22PWXXW00
Whirlpool ED22QFXHB00
Whirlpool ED22QFXHB01
Whirlpool ED22QFXHB02
Whirlpool ED22QFXHB03
Whirlpool ED22QFXHN00
Whirlpool ED22QFXHN01
Whirlpool ED22QFXHN02
Whirlpool ED22QFXHN03
Whirlpool ED22QFXHT00
Whirlpool ED22QFXHT01
Whirlpool ED22QFXHT02
Whirlpool ED22QFXHT03
Whirlpool ED22QFXHW00
Whirlpool ED22QFXHW01
Whirlpool ED22QFXHW02
Whirlpool ED22QFXHW03
Whirlpool ED22RFXFB00
Whirlpool ED22RFXFB01
Whirlpool ED22RFXFB02
Whirlpool ED22RFXFB03
Whirlpool ED22RFXFB04
Whirlpool ED22RFXFN00
Whirlpool ED22RFXFN01
Whirlpool ED22RFXFN02
Whirlpool ED22RFXFN03
Whirlpool ED22RFXFN04
Whirlpool ED22RFXFW00
Whirlpool ED22RFXFW01
Whirlpool ED22RFXFW02
Whirlpool ED22RFXFW03
Whirlpool ED22RFXFW04
Whirlpool ED22RKXXW00
Whirlpool ED22RKXXW01
Whirlpool ED22RQXWW00
Whirlpool ED22RQXXW00
Whirlpool ED22RQXXW01
Whirlpool ED22TEXHN00
Whirlpool ED22TEXHN01
Whirlpool ED22TEXHN02
Whirlpool ED22TEXHN03
Whirlpool ED22TEXHN04
Whirlpool ED22TEXHT02
Whirlpool ED22TEXHT03
Whirlpool ED22TEXHT04
Whirlpool ED22TEXHW00
  #2 (permalink)
Old 11-11-2007, 05:51 PM
Junior Member
MikeThomson is on a distinguished road
Default Have you replaced the filter?
I'm a newbie to repairs on my fridge too and I'm here to get information similar to yours, but it would seem that after reading my book, hollow, small or otherwise deformed cubes come from a poor or under-pressurized water supply. Has anyone messed with the tap that supplies your fridge with water? Have you tried removing the filter and running it without one until you can get a replacement (according to the manual the dispenser will work without the filter installed)... they're just a few suggestions, but the cycling thing is prolly an important dodad to be investigated
  #3 (permalink)
Old 11-11-2007, 06:09 PM
Junior Member
AppRepair is on a distinguished road
Default
There could be a problem with the valve but it is only one of a few things it could be, or even a combination of troubles. Depending on the age of the water lines and fill valve there may be build up that is decreasing your water supply to the ice maker cells that form the ice. If your ice maker is not working at all, it sounds like it's not getting water. I would start with the valve cleaning or replacement and see if that fixes the issue. If not, consider checking the thermostat to the freezer. It should be kept at zero degrees.
Personally, I don't think harvest mode is your problem. Harvest mode is when the ice has been formed and is ready to be dumped from the cells into the holding container. A small amount of heat is applied to the cells to allow the ice to "pop" out before the cells are refilled to freeze the next batch.
  #4 (permalink)
Old 11-11-2007, 09:36 PM
Junior Member
Default
Thanks for the replies guys, It's nice to know that there is help! I removed and replaced the filter, it was very heavy, I don't know much about refrigerator filters, but I know it was 3 times heavier than the new one I replaced it with.
But, still no water to ice maker, I tried it with and without the filter. The water dispenser works fine, pumps out cold clean water like a champ, but no water to ice maker.
I found a mom and pop appliance place that have a water inlet valve assembly for $44, so I think I may try to go get one tomorrow and replace that to see if it helps.
Is it possible that there is something in the ice maker itself that is not working properly to tell the water inlet to "pump" water to the ice maker? A solenoid or micro-switch? Or am I way off base? Or is replacing the water inlet valve the first step in the icy direction?
Thanks again,
Pony
  #5 (permalink)
Old 11-12-2007, 03:42 AM
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default water valve
one way to check the water valve is to switch the electical connector on the water valve. open door and hold door switch in and press your water dispencer in. if you get water to your ice maker water valve is working. or you could also ohm out he coil on the water valve. to test ice maker pull the cover off the front. you will see two little holes on the module about 1/2' apart. put a jumper wire in these holes. ice maker will go into harvest mode. after dial starts to move on ice maker wait 5to 10 seconds and pull jumper wire off. water should come into icemaker when the little arms that eject the ice. are at about 12:00.
  #6 (permalink)
Old 11-14-2007, 07:01 AM
Junior Member
Default
OK, so after a few days of trial and error I think the ice maker itself AND the water inlet valve are bad. Lucky me.
I filled the tray with tap water, let it freeze and waited. The tray seemed to "heat" and melt, re-freeze, repeat. No ejection of cubes.
I popped the front cover off the ice maker and "jumped" across the 2 holes, nada.
I reversed the connecters on the water inlet valve, nothing. Question, can just one coil on the water inlet valve go bad, the door water seems to be working like a champ.
So, I'm thinking need to replace both the ice maker and the water inlet valve, Am I on the right track here guys?
Thanks for the help,
Pony
  #7 (permalink)
Old 11-14-2007, 08:16 AM
Junior Member
spidermonkey is on a distinguished road
Default
my icemaker was not working either, I found that the ice maker was frozen, I took a hair dryer and warmed up the ice maker and little by little you could see the wheel in front of the icemaker moving, I`m pretty sure the wheel was not in the right sequence when it froze up the paddle where stuck in the ice,I did move the wheel manually slowly and if it don`t move don`t force it, keep applying heat, and it will break loose, that how I got my icemaker to work.
  #8 (permalink)
Old 11-14-2007, 08:25 AM
Junior Member
Default
make sure your paddle are in the up mode when it makes ice if there at the bottom of the tray then it`s most likely froozen good luck I hope this this works for you.
  #9 (permalink)
Old 12-28-2010, 06:23 PM
Junior Member
CATHY WILLIFORD is on a distinguished road
Smile Refrigerator Ice Marker
The Light On The On And Off Switch Of The Ice Marker Is Not On. Could The Ice Marker Switch Be Bad. It Is Not Maker Ice. This Is My Mod Gd5shaxkqoo.thank You For Any Help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker problems jorgey64 Refrigerator & Freezer Repair 0 01-31-2010 05:36 PM
Self-solving Whirlpool/KitchenAid Ice Maker Problems terrasharkus Refrigerator & Freezer Repair 2 12-31-2009 07:45 AM
Ice maker problems jpkulp Refrigerator & Freezer Repair 0 06-24-2008 09:03 PM
Whirlpool refrigerator ice maker problems rleal79 Forum Announcements 6 06-20-2008 04:21 PM
Ice Maker problems Charlie L. Refrigerator & Freezer Repair 0 03-11-2008 06:12 AM
