| » Freezer |
Model Number: FFU14F3AWO Brand: Frigidaire Age: 1 - 5 years
My freezer had water under tonight when I got home from work. This has happened before, I blamed the kids for leaving door open. Well it happened again today. I had not voltage at compressor, the thermostat was calling (closed). I tapped the timer on the back of unit and it started. I thinking I have a bad timer. What do you think.............
Thanks DNE Ads By Google Related Models |
Sounds like you found the problem
Did you notice if the fan in the freezer was running? It is usually wired in parallel to the compressor, so if it was also off this raises the odds that you have the correct culprit.
__________________
thanks for the reply no the fan was not running and did not have voltage to it, the defrost element was not hot, but when i tapped the timer unit came on. I checked temp this morn and it was 10, seems to work fine now. This is 2nd time this happened, I cant trust this freezer. Thanks dne |
Well worth investing in a new timer at approx $16.00.
http://www.appliancepartspros.com/pa...a m_id=335228
__________________
| Display Modes | |
| frost free refrigerator/freezer frosting over on back wall or bottom freezer | bwheeler | Refrigerator & Freezer Repair | 2 | 01-31-2011 07:16 AM |
| back panel inside freezer frozen, frige/freezer warm | hydrant71 | Refrigerator & Freezer Repair | 7 | 01-22-2010 06:04 PM |
| bottom drawer freezer leaks pools inside freezer | brian c | Refrigerator & Freezer Repair | 1 | 03-12-2009 05:49 PM |
| Frost Build-Up in freezer (refrig & freezer not as Cold as usual) | boots1 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2009 03:08 AM |
| Refrigerator/Freezer has liquid leaking inside freezer and frig | terrib | Refrigerator & Freezer Repair | 0 | 12-25-2007 10:15 PM |
