| » Defrost system not working |
Model Number: PDS22LBNBB Brand: GE Age: 5 - 10 years
The Defrost system is not working, first I checked the resistence of the heating element it had 31 ohms, and it looked like the thermostat was bad so I replaced it, this did not help. Next I replaced the timer and the system is still not working, so I Rechecked the resistence of the element and it still shows 31 ohms, I can't get a resistence reading on the thermostat but I am getting about 19 volts to the plug that feeds to the thermostat when the system goes in to defrost. Is this voltage ok, is the resistence of the element ok? My next thought is to purchase another thermostat.
Model PDS22LBNBB Is this voltage ok, No but am not sure where you had your meter leads or the settings on the meter. While in defrost mode if the thermostat is open you should see 120 volts AC across it. is the resistence of the element ok? Yes, sounds about right My next thought is to purchase another thermostat. I assume that you are talking about the defrost thermostat. It should measure 0 ohms when frozen. It will open at a few degrees above freezing. Hold it onto an ice cube if you have to or put it into a cup of ice.
__________________
One lead was placed at connection of the heater element and the other lead was placed at the connection in the ceiling of the freezer where the thermostat lead plugs into. This was to bypass the thermostat and heater element.
I would not really trust the voltage measurement, sounds like a ghost voltage.
But may be badly pitted defrost timer contacts. I would check the defrost thermostat if it is 0 ohms then odds are good that the defrost timer is the culprit.
__________________
| Display Modes | |
| Kenmore Refridgerator defrost system failure | Ranger0001 | Refrigerator & Freezer Repair | 4 | 01-14-2010 05:04 AM |
| Defrost System Diagnose Help:evap coil frozen | rogerinutah | Refrigerator & Freezer Repair | 5 | 12-15-2009 11:47 AM |
| Defrost System Not working on GE Side by Side | Jim R | Refrigerator & Freezer Repair | 1 | 08-21-2009 04:38 PM |
| Cleaning System not working | sunnia1 | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2008 06:16 PM |
| Cleaning System not working | sunnia1 | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2008 06:14 PM |
