| » Freezer and Refrigerator not cooling |
Model Number: ABB2221FEW Brand: Amana Age: 1 - 5 years
I have an Amana bottom freezer and neither the freezer or the refrigerator are cooling. Any ideas on what might be causing this?
Thanks Ads By Google Related Models |
If all the fans are running, check the compressor start device behind the compressor side cover. If it rattles when shaken, it's bad, order it here AP4079373
__________________
Thank you. I did check the start device and it did not rattle. Just to be on the safe side I did replace it and it didn't help. I also thought it might have been the defrost timer but that's not it either. Any other idea's?
Thank you |
Check to see if the compressor is running, it will vibrate and the condenser coils will be warm. If the compressor is running and it's hot, it has sucked in non-compresables due to a refrigerant leak. If warm and running, you probably have a worn compressor.
__________________
Thank you. I was afraid it might be the compressor. It does run and vibrate and gets a little warm. Since my last post I did check the continuity of the compressor and got some high readings. I'm pretty much an idiot when it comes to this stuff but my understanding is I should be getting a 0 reading. Is this correct?
Thank you |
Only an amprobe check and low side pressure check will determine status of compressor. You might want to get a pro to look at it, but repair is way too costly.
__________________
MY REFRIGEATOR WAS WORKING THEN STARTING LEAKING WATER THEN IT GOT WARM ON THE INSIDE THERES NO FROST AND THE MOTOR IS VERY HOT CAN U HELP ME PLEASE
| Display Modes | |
| Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling | angiebritt | Refrigerator & Freezer Repair | 3 | 07-22-2010 04:28 PM |
| GE Refrigerator/Freezer Not Cooling Enough | eguerns | Refrigerator & Freezer Repair | 1 | 10-18-2009 08:17 AM |
| refrigerator&freezer not cooling | Gordie | Refrigerator & Freezer Repair | 2 | 10-08-2009 12:11 PM |
| refrigerator not cooling-only freezer | japeuroworker | Refrigerator & Freezer Repair | 0 | 09-16-2009 07:25 AM |
| Freezer and Refrigerator not cooling as before | Pinfish | Refrigerator & Freezer Repair | 5 | 07-05-2009 03:21 PM |
