My LG LSC27950ST refrigerator ice dispenser works but the flapper will not open to deliver the ice. Can anyone tell me what the problem may be? Thanks!
Hello Bjsf. Disassemble the dispenser and see if the flap Part number: AP4438395
is broken, or if the solenoid is bad. Here are the instructions from the manufacture to help you disassemble the dispenser. Hope this helps. Part number: AP4443785
6. DISPENSER 1) Disconnect funnel and button assembly by pulling down and forward.
2) Remove display frame assembly by making a gap between a display frame assembly and door with a flat blade screwdriver and pulling it forward. The cover dispenser is attached with a hook.
3) The display assembly can be connected by pressing the top of the dispenser cover and pushing it after separating the display frame from its housing.
4) Loosen four screws with a phillips screwdriver and pull the funnel assembly to disconnect.
5) The duct cap assembly can be disconnected if the hold lever connecting screw is loosened with a phillips driver.
6) To install the duct cap assembly, insert one end of the spring into the right hole of the dispenser lever and insert the other end into the right hole in the top part of the dispenser. Then attach the holder at the solenoid switch.
Section 7 replacement parts for LG LSC27950ST Refrigerator | AppliancePartsPros.com
