Stopped making ice. Used hair dryer to defrost line coming into ice maker. Nothing happened immediately but with 24 hours it started making ice on its own. Stopped making ice a few days later and went through the defrost steps again though it didn't appear frozen. Didn't start making ice but started leaking all over floor. Turned ice unit off and cleaned up the mess. Defrosted again and it started taking a little water. Some of the individual cube squares were 1/2 full while others were not. Water didn't seem to flow. Last Sunday the ice maker just started leaking water all over the floor again. All this time there have not been any problems with the drinking water dispenser in door. We could draw water without any problems. Just problem with the unit making ice. Not sure what to replace. I do not think water valve since the water in the door worked fine. Any assistance appreciated. Contact me if you need more information: brianc2k@yahoo.com
