Discuss
Frigidaire Ice Maker
 in
Refrigerator & Freezer Repair
I have a Frigidaire side by side ref/freezer. The water on the door comes out very slowly and now
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire Ice Maker
  #1 (permalink)
Old 02-09-2009, 10:17 AM
mtda1318 mtda1318 is offline
Junior Member
mtda1318 is on a distinguished road
Default Frigidaire Ice Maker
Brand: Frigidaire   Age: 1 - 5 years
I have a Frigidaire side by side ref/freezer. The water on the door comes out very slowly and now the icemaker has stopped making ice. I ordered a new water valve and wanted to know if you thought this was the problem.
Mike
  #2 (permalink)
Old 02-12-2009, 08:04 AM
shadow0000 shadow0000 is offline
Junior Member
shadow0000 is on a distinguished road
Default
Removing the old unit was easy enough, just loosened two screws that attach unit to side of freezer and disconnected the wiring harness. But the new unit never goes in quite as easily because it's always just a little different from the original. In this case, the wiring ended up being about six inches longer and the excess had to be stuffed behind a shield at the rear of the unit. Theoretically, the wire could have been pushed back through the opening, but it got jammed and wouldn't go. I had to remove side rails and pry the shield forward in order to get the wiring back out of the way. The unit is a narrow side by side, so there wasn't a lot of room to move around. But it wasn't difficult, just tedious. I had to make sure the wiring did not come into contact with the heating element at the bottom of the icemaker. Once installed it worked great.
____________________
Scotsman Ice Machine
  #3 (permalink)
Old 02-12-2009, 07:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Mike,
How old is the water filter (if there is one)?
__________________
  #4 (permalink)
Old 02-13-2009, 04:05 AM
Junior Member
Default
It was in the refrigerator when we bought the house. We bought last April.
  #5 (permalink)
Old 02-13-2009, 02:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would replace the water filter first. If you need the right part number then post the complete model number of the refrigerator.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire ice maker WildmanWilson Refrigerator & Freezer Repair 1 09-20-2009 05:05 PM
Frigidaire Ice Maker Robert Laplante Refrigerator & Freezer Repair 1 06-10-2009 09:47 AM
Frigidaire ice maker mpalmatier Refrigerator & Freezer Repair 1 01-26-2009 03:43 PM
Frigidaire Ice Maker waltert Refrigerator & Freezer Repair 3 06-25-2008 03:00 PM
Frigidaire Ice Maker rlprosser Refrigerator & Freezer Repair 4 11-04-2007 12:19 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
