Discuss
Self Defrosting Freezer
 in
Refrigerator & Freezer Repair
My Roper RS22AQXKQ00 side by side leaked water from the freezer section, I unplugged it for a while and plugged
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Self Defrosting Freezer
  #1 (permalink)
Old 11-08-2007, 09:37 PM
DEMETRICK DEMETRICK is offline
Junior Member
DEMETRICK is on a distinguished road
Default Self Defrosting Freezer
Model Number: RS22AQXKQ00   Brand: Roper   Age: 1 - 5 years
I unplugged it for a while and plugged it back in and now it just will not get cold enough for my frozen foods. The ice maker will not make any ice either.
I am pretty sure the water was coming from the ice-maker area. Can some one help me with this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-09-2007, 04:00 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default water leak
Suggest you get a couple of thermometers to place in the fridge&freezer so you know what temps you're getting with each... See if the compressor is shutting off prematurely before reaching customary temps... Next check for an ice buildup on the evaporator coil behind the inside back wall of the freezer compartment... If there isn't any my guess from 4K miles away is a defective defrost end t-stat (AP3950837)... I just ran into one of these 3 weeks ago on what looks like a similar model... This goofy fridge worked fine when I showed up on 3 different visits but the 4th was when it was finally caught opening the cooling circuit prematurely... Without a cold enough freezer you're going to have ice melting and running out of it... Good luck, kooler
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana BX21VL not defrosting biggxj Refrigerator & Freezer Repair 0 10-07-2007 05:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
