The freezer will start to get hot and quit making ice. I can thaw it out and plug back in and it will work for a 2 - 4 months. I checked the drain tube, and it is not plugged. I replaced the defrost timer. When the heater comes on it starts pulling 4 amps. Any ideas?
Here are your parts Replacement parts for FRT22INLHC models | AppliancePartsPros.comI use the HC0. I am assuming that you have confirmed that the evaporator coils are icing up causing the problem. One symptom of this would be the compressor running constantly. If not then it may be a main thermostat problem. Odds are that the defrost thermostat (Item 21 in Section 4) has gone intermittent. The heater can also go intermittent but it is very rare. Note: Often but not always, you can see that the defrost thermostat is bulged/deformed. |
THIS FORUM IS DEAD!!!!!!! |
