Discuss
freezer not cold enough, fridge fine
 in
Refrigerator & Freezer Repair
My freezer does not stay at a consistent temperature. The fridge seems to be fine. After I empty the ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer not cold enough, fridge fine
  #1 (permalink)
Old 11-08-2007, 05:45 PM
tambo tambo is offline
Junior Member
tambo is on a distinguished road
Default freezer not cold enough, fridge fine
Model Number: mtf1895aeq   Brand: Maytag   Age: 1 - 5 years
My freezer does not stay at a consistent temperature. The fridge seems to be fine. After I empty the ice tray, everything seems fine but after a day or so the new ice in the tray slightly melts together and the contents of the freezer get soft. Any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-09-2007, 05:20 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default heater
Make sure that the heater under the icemakeer is going off. You could have a icemaker that is sticking sometimes
  #3 (permalink)
Old 11-16-2007, 06:15 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default tricky one
These kinds of problems can be difficult to diagnose, suggest placing thermometers (AP3549145) in the freezer and fridge so you're not guessing what the temps are... The tricky part is to observe what's happening when you find the freezer temp up higher than normal... You shouldn't ever have soft product so something is causing this rise in temp.. Once I made 4 trips to a fridge before I finally found the condenser fan not running when it should have been... Everything checked out fine the first 3 trips...
Your model does have the accumulative defrost control so the timer only advances when the thermostat is calling for cooling... Try replacing the defrost end thermostat (AP4071978) first if this problem continues.. Good luck, kooler
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge not cooling but freezer is fine jessibadillo Refrigerator & Freezer Repair 5 10-26-2007 08:37 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
refrig not blowing cold but freezer fine chaikid Refrigerator & Freezer Repair 1 09-11-2007 08:14 PM
Fridge not cold, freezer fine: fan problem? eyanyo Refrigerator & Freezer Repair 1 08-27-2007 11:00 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
