Maytag plus refrig & freezer side not cooling
Has slowly not been cooling even with the temperature settings to maximum. Last year replaced "board" for $240. I was wondering how much this repair would cost me.
Pull the freezer panel and check frost pattern. Thaw out if completely frozen.
If you have a meter, check the defrost heater and thermostat, should be around 30 ohms with the thermostat at freezing temperature.If bad order AP4069790. If ok, replace adaptive defrost board behind the control panel AP4070403 |
| All times are GMT -7. The time now is 11:51 PM. |
