Fridge was 70 + degrees and freezer was fine. After looking closer, realized ice build up on freezer coils. Replaced defrost heater assy #ap4069923 AND adaptive defrost control #ap4070403. It took several hours for fridge to get to 40 deg. Freezer fine. Fridge will not get any colder regardless of setting.When door is open too long,(to refill) it took a very long time to get back to 40 deg. Is there something else I should check? Thank you for any help.
I would check for an ice clog in the air return behind the crisper drawer. I would also check that you put back the control panel properly to allow proper air flow into the fridg section.
