our freezer door is at least 20 yrs olf - has been in a hot garage all these years - we noticed the door not sealing, we weren't hearing the vacuum sound we were used to hearing and there was no tug or pull when opening the door - per the manual we replaced the magnetic door gasket just this morning and defrosted it since the door not sealing made it ice up - the new gasket seems to seal all the way around the door except for a 4 inch section on the lower left side (which is the side that opens). however, the door is still not sealing tightly - no pull when opened. currently, we have a huge clamp on the freezer trying to create a seal. what else should we do? thanks
