My ice door isn’t working properly on my frigidaire FRS26ZGEW2. I can look up in there and see the ice door wire is rusted and broken on one side, so that’s part of my problem. I may need the spring and the ice door assembly also, not sure. (I have looked at diagrams and part numbers) I guess my main question is how do I get this apart to get to all this stuff? Also, when i press the ice dispenser button, the ice door is supposed to be opened immediatly by a solenoid, correct? thanks very much
