Discuss
Water Inlet Valve issue
 in
Refrigerator & Freezer Repair
I installed a new water inlet valve because the old one was leaking. Now the ice maker water runs whenever
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water Inlet Valve issue
  #1 (permalink)
Old 05-20-2011, 05:58 PM
Junior Member
StevenClay is on a distinguished road
Default Water Inlet Valve issue
Brand: GE   Age: 5 - 10 years
I installed a new water inlet valve because the old one was leaking. Now the ice maker water runs whenever getting water through the door dispenser. It seems like the new inlet valve is defective. Could that be it?
Ads By Google
  #2 (permalink)
Old 05-20-2011, 11:41 PM
Junior Member
keeper is on a distinguished road
Default
Man I wish I knew for sure, and to be able to give back and help out
I think I have a bad inlet valve myself, I have no water at all.
Apparently no one else knows as well....
So when you access water from your cup dispenser the ice dispenser flows water also? I would make sure you have like for like valves and its plugged in correctly?
Obviously I have no experience but do want to help..... we all give where we can.......
keep us posted.......
  #3 (permalink)
Old 05-23-2011, 10:54 AM
Junior Member
Default Still Puzzled
I'm pretty sure things are hooked up correctly. To test the connections I re-connected the original inlet valve. It displays the same problem, water flows to the ice making tray whenever the door water dispenser is used. It must be some other problem that we just didn't notice before, we don't use the water dispenser often.
  #4 (permalink)
Old 05-23-2011, 11:04 AM
Junior Member
Default
is it possible to cross connect the wires?
I know on my inlet valve there are two electrical connections, is it possible they are wrongly connected?
  #5 (permalink)
Old 05-24-2011, 08:05 AM
Junior Member
Default
That sounds like it would cause it to act this way. I had been a little confused on the water line connections but I thought I had been careful with the electrical connections. It's worth a try though. Thanks for the idea.
As far as the water line connections, the line to the ice maker and the line to the water dispenser are different sizes so those are for sure right. The one I may have mixed up are the ones to the filter, but I don't really think it matters, one goes to the filter and one returns so as long as the water is flowing, does it matter which is which?
  #6 (permalink)
Old 05-24-2011, 10:14 AM
Junior Member
Default
I would imagine it would, there certainly has to be some one in this collective forum with more knowledge on this then myself.... try it and let us know..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Inlet Valve Floyd Mooneyham Refrigerator & Freezer Repair 9 01-22-2011 07:27 AM
Water Inlet Issue AJ Devitz Refrigerator & Freezer Repair 2 10-10-2010 07:17 AM
Water Inlet Valve tsquic46 Refrigerator & Freezer Repair 0 07-28-2010 08:14 AM
valve inlet for water and ice zadian Refrigerator & Freezer Repair 4 03-16-2009 11:44 AM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 10:34 PM
