Freezer area source of loud humming for period of 60-120 seconds maybe every 2-3 hours---thought it was the ice maker but was not---next thought was the water inlet valve for ice maker, disconnected power to valve but that was not the answer---further inspection leads to the back wall of the freezer where vent is---have no idea what is behind there or what could be making the noise---any ideas---thanks
Originally Posted by: johnt49 Freezer area source of loud humming for period of 60-120 seconds maybe every 2-3 hours---thought it was the ice maker but was not---next thought was the water inlet valve for ice maker, disconnected power to valve but that was not the answer---further inspection leads to the back wall of the freezer where vent is---have no idea what is behind there or what could be making the noise---any ideas---thanks John, The only component left in the back wall of the freezer compartmenmt is the evaporator fan motor, Part number: AP4128247
They can get a bit noisey when they're about to fail. Good Luck, :) :) :)
