Sirs, My Refrigerator is not cooling properly, just intalled new gasket from you last weekend , freezer works fine,door to frig opens ,but heats up to 55 plus during day setting freezer and frige to max(9) at night was 30 at 7am,but by 4pm is up to 50+. Could it be the thermostat on freezer? help if you can think of what to do next? Thanks jim Holmes
]Sirs, My Refrigerator is not cooling properly, just intalled new gasket from you last weekend , freezer works fine, the small door to frig opens and closes to defrost, did have a build up of frost on fridge side this morning under door ,but heats up to 55 plus during day setting freezer and fridge to max(9) at night was 30 at 7am,but by 4pm is up to 50+. Could it be the thermostat on freezer? Is there a fridge themostat or just the freezer? help if you can think of what to do next? Thanks jim Holmes
After removing the ice maker which had alot of ice build up and the small frig door going from freezer to frig appeared frozen shut. I removed all the ice. Removed frozen food to another freezer, removed the back panel and the was no light frost build up on the fins,but a heavy ice build up on the right side of the fins next to the frig side. Now ice is removed, and replugged unit back in to see what happens overnight.. Thanks for any help. jim
Keep us posted Jim. Good luck.
