tmcraintx
#1 Posted : Wednesday, November 7, 2007 8:06:14 AM(UTC)
tmcraintx
The ice maker fill line that runs up the back of fridge is full of water it is not pumping up into maker to make ice anymore. I can fill maker with water and it produces ice. I need to know what that part is that pumps water into maker that the in line and out line are connected to.
kooler
#2 Posted : Wednesday, November 7, 2007 11:04:11 AM(UTC)
kooler
My guess is the water line is frozen at the point it enters the freezer compartment altho the parts diagram doesn't show an ice maker with your particular model... Could be the ice maker was field installed after the refrigerator was first purchased... Suggest using a hair dryer to remove any ice buildup in the water line and if this condition persists then replacement of the water fill solenoid may be necessary... Look for any part numbers on the valve itself to help identify a replacement... Good luck, kooler
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Cafe induction range issue... Help please! (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2023 7:31:31 PM(UTC)
Help - Model FGIF3036TDA Oven does nothing (Oven Repair (including Ranges and Cooktops))
by norride9 1/25/2023 3:34:27 PM(UTC)
