I have an FFU17FC5CW4 Frigidaire Freezer. I believe the fan is bad, but not sure. I removed the inside panel and noticed the fan not spinning. When I touched the fan it started spinning again. This is the second time this has happened. The first was about a year ago and once the fan started spinning I didn't have any more problems, until now. Both times, the freezer is ice cold on the bottom, so I know it's a circulation issue, but is there another part which could also cause the fan not to spin?
Originally Posted by: Geno H I have an FFU17FC5CW4 Frigidaire Freezer. I believe the fan is bad, but not sure. I removed the inside panel and noticed the fan not spinning. When I touched the fan it started spinning again. This is the second time this has happened. The first was about a year ago and once the fan started spinning I didn't have any more problems, until now. Both times, the freezer is ice cold on the bottom, so I know it's a circulation issue, but is there another part which could also cause the fan not to spin? Geno, You have a basic upright freezer, With everything but the eavaporator motor running, you have a bad motor(most likely) or a loose wire connection(less likely). Part number: AP4368950
Good Luck, :) :) :)
Originally Posted by: Joe / APP Team Geno, You have a basic upright freezer, With everything but the eavaporator motor running, you have a bad motor(most likely) or a loose wire connection(less likely). Part number: AP4368950
Good Luck, :) :) :) Thanks Joe, I'll order the part you recommended. Hope it works.
Originally Posted by: Geno H Thanks Joe, I'll order the part you recommended. Hope it works. Geno, OK, I'm really sure it'll solve the problem. :) :) :)
