The water dispenser nozzle has deteriorated and broken off. I ordered the part, and found it comes attached to a long black hose. I can't find a way to access the hose, as it seems that the front door unit must be removed, and it does not want to come off. The trim was easy to remove. Is there another screw to take off? Is there a way to just replace the nozzle? I can do anything once I see how to do it. Thanks! Kristi K
