Discuss
Chest Freezer no go after Flood
 in
Refrigerator & Freezer Repair
Freezer floated around in 7 feet of muddy water. This model has no exposed evap coils. I cleaned out all
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Chest Freezer no go after Flood
  #1 (permalink)
Old 11-06-2007, 11:27 AM
EngineerMike EngineerMike is offline
Junior Member
EngineerMike is on a distinguished road
Default Chest Freezer no go after Flood
Model Number: mfc13m3bw0   Brand: White-Westinghouse   Age: More than 10 years
Freezer floated around in 7 feet of muddy water. This model has no exposed evap coils. I cleaned out all mud from exposed parts, plugged it in. Motor ran till relay got smokin hot & fried. I replaced relay & overload. Didn't replace capacitor as it looks fully potted.
Now I plug it in & compressor runs drawing 0.8A steady but not producing cold. I turn temp control & hear audible click (presumably relay?) & motor kicks up faster w/louder hum, and amps go to 8.0. Halfa sec later another audible click (overload?), amps go to zero & no noise. After a min or two another click & amps go to 0.8 steady w/low hum from compr. but no cold as above.
My suposition is mud in temp control (which appears to be a reostat?) that I can't get out (I tried mass quantities of contact cleaner, but good access isn't possible w/out disassembling control & probably nuking it anyway.
Questions:
1) am I on right track w/replacement of temp control? If not what suggestions?
2) How do I replace the temp control (particularly sensor end which is currently inside the sheet metal casing somewhere)? Looks like the sensor end gets buried somewhere inside case probably next to inside skin of freezer compartment. I'm wondering if I can drill hole thru to inside compartment (storage area of freezer) & epoxy it to inside surface of compartment then cover it w/plastic sheet.
Thanks for any help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Repairing a Gibson 20 chest freezer mattcoffey Refrigerator & Freezer Repair 0 10-08-2007 04:18 PM
sears (gibson) chest freezer won't cool moegs Refrigerator & Freezer Repair 1 08-03-2007 12:01 PM
Chest freezer leaking water larena Refrigerator & Freezer Repair 2 07-30-2007 12:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
