Discuss
frost free refrigerator/freezer frosting over on back wall or bottom freezer
 in
Refrigerator & Freezer Repair
My Amana refrigerator is about 5 years old. Today I opened the freezer to get something out and noticed food
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » frost free refrigerator/freezer frosting over on back wall or bottom freezer
  #1 (permalink)
Old 01-29-2009, 03:57 PM
Junior Member
bwheeler is on a distinguished road
Default frost free refrigerator/freezer frosting over on back wall or bottom freezer
Brand: Amana   Age: 1 - 5 years
My Amana refrigerator is about 5 years old. Today I opened the freezer to get something out and noticed food was starting to thaw. My refrigerator has a bottom freezer. Also the back wall of the freezer was frosted over. Any ideas what may be wrong. Thanks.
Ads By Google
  #2 (permalink)
Old 07-22-2010, 01:51 PM
Junior Member
phil8192 is on a distinguished road
Default
Quote:
It's most likely a failure of one of the automatic defrost components -- the defrost timer, the defrost heater element, or the defrost thermostat. If any one of them fails, the evaporator coils won't get defrosted every 6-8 hours as they should and quickly get clogged with frost. Once they are clogged, cold air can't flow past the coils and circulate, so the freezer and fresh food sections tend to get warm.
If you're willing and capable of doing the work yourself, the parts will cost somewhere in the range of $140-$200, if all need to be replaced; the defrost heating element is typically the most expensive, running around $60-$70 from an appliance parts store, followed by the defrost timer. If it's just one part, such as the defrost thermostat, it can be purchased for less than $20. Some newer refrigerators use an electronic "motherboard" that controls all functions in the refrigerator, and instead of a defrost thermostat, these units use a thermistor, not likely to fail. If the defrost heater element checks out OK (it should have a resistance reading in the range of 10-40 ohms), then one would need to replace the entire motherboard.
  #3 (permalink)
Old 01-31-2011, 07:16 AM
Junior Member
sembo is on a distinguished road
Default my freezer build ice
HI why is my kenmore freezer build ice..thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frost on back wall of REFRIGERATOR mar3148 Refrigerator & Freezer Repair 0 08-31-2009 08:49 AM
ice buildup in frost free freezer & refrigerator too warm lawlady122 Refrigerator & Freezer Repair 2 12-03-2008 05:27 AM
Freezer has frost on back wall, fridge not cold enough firfitr247 Refrigerator & Freezer Repair 7 12-02-2008 04:18 AM
icing under freezer in (frost-free!) refrigerator compartment bshaff Refrigerator & Freezer Repair 2 07-31-2008 11:28 AM
Back Freezer wall keeps frosting up arnesons Refrigerator & Freezer Repair 2 03-11-2008 07:40 AM
