This just started recently, but sometimes when i use the water dispenser on my LG side by side, the water doesnt stop, or at least doesnt stop right away. This causes overfilling of your glass and a big mess on the floor. It sounds like a lazy selenoid or valve in the door, but i cant be sure. When it deos this the only way to get it to stop is to cycle the switch a few times or press the ice button. Any ideas? TIA
Originally Posted by: Ryeguy8585 This just started recently, but sometimes when i use the water dispenser on my LG side by side, the water doesnt stop, or at least doesnt stop right away. This causes overfilling of your glass and a big mess on the floor. It sounds like a lazy selenoid or valve in the door, but i cant be sure. When it deos this the only way to get it to stop is to cycle the switch a few times or press the ice button. Any ideas? TIA Mine did the same thing about 2 months ago.l There is a control button inside the rubber oval dispenser that gets stuck. Two days ago mine broke, another giant flood. Tonight I am searching for a replacement part. No luck. Tomorrow I will call LG. A small part, no dispensing without it. It should not cost over a $1.00.lol.:p
Originally Posted by: Ryeguy8585 This just started recently, but sometimes when i use the water dispenser on my LG side by side, the water doesnt stop, or at least doesnt stop right away. This causes overfilling of your glass and a big mess on the floor. It sounds like a lazy selenoid or valve in the door, but i cant be sure. When it deos this the only way to get it to stop is to cycle the switch a few times or press the ice button. Any ideas? TIA Mine did the same thing about 2 months ago. There is a control button inside the rubber oval dispenser that gets stuck. Two days ago mine broke, another giant flood. Tonight I am searching for a replacement part. No luck. Tomorrow I will call LG. A small part, no dispensing without it. It should not cost over a $1.00.lol.:p
