Discuss
Refrigerator Leaking from freezer into refrigerator
 in
Refrigerator & Freezer Repair
I opened the refrigerator and there was water leaking from the top of the refrigerator/bottom of the freezer. Any ideas
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Leaking from freezer into refrigerator
  #1 (permalink)
Old 05-05-2011, 07:05 PM
Junior Member
BootsieP is on a distinguished road
Default Refrigerator Leaking from freezer into refrigerator
Brand: Whirlpool   Age: More than 10 years
I opened the refrigerator and there was water leaking from the top of the refrigerator/bottom of the freezer. Any ideas what could be causing this?
  #2 (permalink)
Old 05-06-2011, 04:37 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sounds like the drain tube is plugged.
It runs from under the evaporator coils in the freezer to the drip tray under the unit.
Some units drip into a funnel like fitting at the top, back of the fresh food section and then down to the drip tray.
Can be cleared with a turkey baster and warm water, compressed air or a piece of wire.
Check that the drain tube is not clogged with dust etc. at the drip tray.
You might as well clean the condenser/compressor fan and the coils while you are down there.
If you see stuff growing in the tube flush it with a 10% bleach solution, let it sit for 15 minutes and then do it again. After another 15 minutes flush with clean water.
Be careful that the drip tray does not overflow and emty the drip tral after you are done.
Be sure to unplug the unit while doing this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator freezer is leaking mariebarba Refrigerator & Freezer Repair 1 05-03-2011 05:55 AM
Refrigerator Leaking from the Freezer Side mgalvan Refrigerator & Freezer Repair 1 04-10-2011 07:03 PM
LG is leaking water in freezer and won't go below 45 degrees in refrigerator lindabertaut Refrigerator & Freezer Repair 0 08-04-2009 04:27 PM
freezer part of refrigerator leaking water timchi29 Refrigerator & Freezer Repair 4 06-24-2009 10:48 AM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
