Discuss
refrigerator compressor and possible relay switch
 in
Refrigerator & Freezer Repair
Hi, Our roughly 20-year-old KitchenAid side by side refrigerator/freezer stopped working, with both sides thawing completely. We were out of
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator compressor and possible relay switch
  #1 (permalink)
Old 05-04-2011, 06:48 PM
Junior Member
cindiandbob is on a distinguished road
Default refrigerator compressor and possible relay switch
Brand: Kitchen Aid   Age: More than 10 years
Our roughly 20-year-old KitchenAid side by side refrigerator/freezer stopped working, with both sides thawing completely. We were out of town for a couple days. It was making a humming sound when we found it (we unplugged it right away). When the refrigerator is plugged back in, the compressor clicks occasionally but does not come on.
In calling for a potential local repairman, one of them told me that a relay might be able to be installed on the compressor if the compressor was bad. The repairman we had out (a different one than had told us about the relay) said our compressor was dead. He tried to install a start device, but it did not work/repair the problem.
-->Is a start device the same as the relay that we were told might work to repair the compressor?
-->Based on what I've described, would you think it is our compressor that's bad, or might there be something else (something repairable) that could cause the problem?
Thanks a lot,
Bob"
  #2 (permalink)
Old 05-05-2011, 02:52 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
The repairman is probably right, either a burnt start winding, or a blown open winding. You can install a new start device to confirm.
__________________
  #3 (permalink)
Old 05-07-2011, 02:03 PM
PET PET is offline
Junior Member
PET is on a distinguished road
Default
Cini and Bob,
It has been a few days, what was the outcome? I saw a post, but it didn't answer your question(s). It sounds to me that the repair guy over-rode the relay (with a "start device") to test the compressor---and that the "compressor" didn't work. (Which I thought was rare to fail.) And therefore, if I am correct, the relay is not bad, the compressor is.
That's the best I can offer for now. I was just checking to see if there was an answer here for a similiar problem I'm having; whereas I'm trying to determine the same as you---and I'm hoping it is the relay. (I read that compressors rarely fail, and if you think about it, that is the heart (of your refrig costs), where the relay is only a glorified (low cost) switch.
Best of luck---pls tell me how you made out-results and costs! pt
  #4 (permalink)
Old 05-07-2011, 06:16 PM
Junior Member
chao_lu@hotmail.com is on a distinguished road
Default
Sir,
I just fixed my Kenmore refrigerator. I want to share my experience here.
My Kenmore refrigerator is model # 25357672791, side by side refrigerator. It stopped working a few days ago.
With plugging in power, light on and compressor not working.
I unplugged the relay (by the side of compressor), and shaked the relay and it seems relay had broken inside.
So I went to this web site: Appliance Parts search by model or part number | AppliancePartsPros.com, I bought my new relay, it cost $2.49 plus $7.25 shipping cost. In two days, I received new relay.
The relay for my refrigerator has also protector assembled, so I pulled the old protector out from the side of compressor and assembled old protector with new relay. Then I plugged the new relay/ old protector assembly back to side of compressor.
When I plugged into power and got small click sound from somewhere in refrigerator, but the fan and compressor seem dead and did nothing. Strange????
Then I did the tests, step by step under the situation of “Refrigerator does not run but the light works” by following this website: compressor of refrigerator can not run normally.-BidAnswer.com Fast helps for all your questions.
All components are good, but light keeps on and the fan and compressor do not working.
I knew that all my parts are good, just something inside cut power off for fan and compressor.
When I checked Defrost Timer, I noted this defrost timer has reset button. It tells we need to reset the defrost timer.
(The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. This is my case.)
So I use a small screw drive to push that little white dot button for about 30 seconds, my refrigerator started. I solved the problem and fixed my refrigerator.
Hope this will help.
  #5 (permalink)
Old 05-08-2011, 03:51 AM
Senior Expert
APP Volunteer
Default
What part number did you get for so cheap a price? Also, your defrost timer may have stuck in defrost, it should cycle into defrost about every nine hours. Just check to confirm it will not hang up again. I have never seen a reset button on a defrost timer, I would suspect you just turned the timer till it came out of defrost.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compressor relay/overload switch Michelle1985 Refrigerator & Freezer Repair 3 12-27-2011 01:47 AM
Bad Compressor, Relay, Other? darrellmak Refrigerator & Freezer Repair 0 07-30-2010 07:03 AM
Compressor Relay timh Refrigerator & Freezer Repair 0 06-04-2010 06:03 AM
relay or compressor Chuck P Refrigerator & Freezer Repair 1 07-06-2009 03:12 PM
compressor relay Mickeyboy Refrigerator & Freezer Repair 2 12-30-2008 11:08 AM
