Bill Bo
#1 Posted : Friday, January 23, 2009 12:15:03 PM(UTC)
Bill Bo
I need some help there is no water and no ice in my ice maker. After looking
it over I can see in the motor assembly that it is part way though the cycle.
The rotation of the ice removal forks is about at the 2 o'clock position.
There seems to be power to the motor. Any ideas on possible repair?
Bill Bo bjbohannon@gmail.com
SublimeMasterJW
#2 Posted : Friday, January 23, 2009 1:51:26 PM(UTC)
SublimeMasterJW
Ok that is called a modular design. The head itself can be easily replaced but it cost as much as a cheap one down at Lowes. The trick is you buy the generic one with that type head on it. Then you use your wiring harness from your old one so you can power up the new one. They all come from the same source. And they come without the harness plugged in. So you have the option to use the 3 or 4 they supply or the one that fits your ice box. Clever ain't it.
SublimeMasterJW
#3 Posted : Friday, January 23, 2009 2:02:12 PM(UTC)
SublimeMasterJW
If you don't want to go the replacement route you could try this: put some water in the ice mold. If it kicks out a batch but it don't make no more then you might have a bad water valve. If it dont then you might have a bad mold thermostat. The thermostat is cheap and easy to replace. Remove the IM from the ice box and get the cover off. Remove the feeler arm. Remove the 3 screws holding the head on there. Remove the 2 screws holding the ice mold to the frame. Remove replace the ice mold thermostat. Put it all back together. There is no wiring and you cant put it back wrong. 5 minute job.
Oven.doc (68kb) downloaded 3 time(s).
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#4 Posted : Friday, January 23, 2009 2:14:56 PM(UTC)
SublimeMasterJW
If the water valve is good and the mold thermostat is good and the coils beneath the machine are fairly clean so the ice box can get down to 28 F then the small copper plate behind the main drive gear might be dirty from the arcing each time it makes contact at the end of the cycle. If you CAREFULLY remove that main drive gear you can sometimes clean up that copper plate and it will start powering up the water valve once more.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
