| » ice maker - water freezing in tube |
Model Number: ed25pqxfn01 Brand: Whirlpool Age: 5 - 10 years
the water is freezing in the tube. i turned the freezer to the lowest setting. never thawed out so i melted the ice with warm water and a large siringe. in a couple of hours - the tube had ice in it and never made a single cycle. anything obvious?
Quote:
does not completely close and the tube will freeze shut as a small ammount of water will continuosly dribble into the tube when the valve shuts off causing the tube to freeze solid. I tried to clean the valve but that did not work so I replaced it and that ended the problem. A new valve is not expensive. Hope this helps |
| Display Modes | |
| Ice maker not getting water | DBBromberg | Refrigerator & Freezer Repair | 3 | 09-24-2007 09:30 AM |
| Ice Maker dispensing ice and water | karen54 | Refrigerator & Freezer Repair | 0 | 08-20-2007 07:42 PM |
| Milk and water freezing temp turned down. thermostat? | bidd1 | Refrigerator & Freezer Repair | 1 | 08-11-2007 04:36 PM |
| Water accumulating and freezing in bottom of freezer | Bigz | Refrigerator & Freezer Repair | 0 | 07-31-2007 08:45 PM |
| Ice maker not getting water. | brandon58 | Refrigerator & Freezer Repair | 1 | 07-30-2007 03:52 PM |
