The ice dispenser makes ice and the water dispenses.While holding the door switch, there is no ice dispenser motor noise while attempting to dispense ice. I tested the continuity on both micro switches and while depressing the micro switches they both show readings. Does this mean they are both open or closed? Could they both be bad switches? If so, then how am I getting water with a bad switch?
