| » Maytag Icemaker |
Model Number: MTF2195AEB 21 Cu. Brand: Maytag Age: 1 - 5 years
Maytag MTF2195AEB 21 Cu
I have some issues with my ice maker. works but when is full of ice and the Arm, sensor stops sometimes still a little water on the line, causing ice inside the Grommet, fill tube and in the plastic Bearing on the ice maker. did you know what is causing this? Thanks Ads By Google Related Models |
Quote:
The most common problem for that description, is a "seaping" fill valve, Part number: AP4071381 The water continues to drip into the fill tube.and icemaker, the icemaker overfills and the water left in the grommet freezes. I'd start there. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Icaliente,
You're welcome, it's our pleasure to assist you. Let us know how things go,when you're done. Good Luck,
__________________
i replaced the part like you sugest and i put and icemaker inline filter. Seems to work. But when you raised the arm for stop making ice 2 or 3 days later the grromet is filled out with froze water. Do i need to replace the whole icemaker?
Thanks |
Quote:
You installed a new fill valve, and an in line water filter. The filter is a good idea, But, You may have dropped the water pressure to the fill valve, causing the drip which eventually freezes in the grommet. You may want to remove or bypass the filter for a few days and see if the issue occurrs, before you replace the icemaker. Good Luck,
__________________
OK,
Let us know what you find, aftert you bypass the filter for a few days. We can go from there.
__________________
Quote:
At this point, I have to make an educated guess. You have to maintain a minimum and constant water pressure of 25 psi at the fill valve connection at the back of the refrigerator, in order to maintain proper operation of the water system. You may want to recheck the shut off valve and supply tubing for debris, restrictions, and twists or kinks(especially if it is a self piercing saddle valve assembly). You've pretty much eliminated the refrigerator as the the issue, with all the work and bypasses you performed and parts you replaced. Good Luck and Thanks,
__________________
| Display Modes | |
| Need Help with Maytag Icemaker | granadino | Refrigerator & Freezer Repair | 0 | 04-22-2011 07:59 AM |
| Maytag in door icemaker | rich636 | Refrigerator & Freezer Repair | 0 | 02-14-2011 06:57 AM |
| Maytag Icemaker Issue | otis44 | Refrigerator & Freezer Repair | 4 | 11-30-2010 09:50 AM |
| Maytag Ice2O icemaker | gkledaras | Refrigerator & Freezer Repair | 1 | 08-27-2009 04:07 AM |
| maytag icemaker repaired | jgv | Refrigerator & Freezer Repair | 0 | 04-02-2009 03:00 PM |
