Discuss
freezer leaks water
 in
Refrigerator & Freezer Repair
The freezer is leaking water around the drain tube and on to the floor. I cleaned the tube out and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer leaks water
  #1 (permalink)
Old 05-01-2011, 02:10 PM
Junior Member
ed55 is on a distinguished road
Default freezer leaks water
Model Number: FRS26R4CB3   Brand: Frigidaire   Age: 1 - 5 years
The freezer is leaking water around the drain tube and on to the floor. I cleaned the tube out and it did not help. It appears to be getting under the grommet inside and running down the outside of the tube underneath the refridgerator that goes to the pan. Is there supposed to be a space between the drip pan and the grommet on the drain tube, the holes do not seem to line up with each other causing the water to run down the side of the grommet and not go through the tube properly. But instead lays on the plastic bottom around the grommet and leaks under it and down the tube unto the floor. Any suggestions?
Thank you Ed
Ads By Google
Related Models
Frigidaire FRS26R4CB3 Frigidaire/refrigerator
Frigidaire FRS26R4CB4 Frigidaire/refrigerator
Frigidaire FRS26R4CB5 Frigidaire/refrigerator
Frigidaire FRS26R4CB6 Frigidaire/refrigerator
Frigidaire FRS26R4CB7 Frigidaire/refrigerator
Frigidaire FRS26R4CB8 Frigidaire/refrigerator
Frigidaire FRS26R4CBA Frigidaire/refrigerator
Frigidaire FRS26R4CBB Frigidaire/refrigerator
Frigidaire FRS26R4CBC Frigidaire/refrigerator
Frigidaire FRS26R4CBD Frigidaire/refrigerator
Frigidaire FRS26R4CBE Frigidaire/refrigerator
Frigidaire FRS26R4CBR Frigidaire/refrigerator
Frigidaire FRS26R4CBS Frigidaire/refrigerator
Frigidaire FRS26R4CQ0 Frigidaire/refrigerator
Frigidaire FRS26R4CQ1 Frigidaire/refrigerator
Frigidaire FRS26R4CQ2 Frigidaire/refrigerator
Frigidaire FRS26R4CQ3 Frigidaire/refrigerator
Frigidaire FRS26R4CQ4 Frigidaire/refrigerator
Frigidaire FRS26R4CQ5 Frigidaire/refrigerator
Frigidaire FRS26R4CQ6 Frigidaire/refrigerator
Frigidaire FRS26R4CQ7 Frigidaire/refrigerator
Frigidaire FRS26R4CQ8 Frigidaire/refrigerator
Frigidaire FRS26R4CQB Frigidaire/refrigerator
Frigidaire FRS26R4CQC Frigidaire/refrigerator
Frigidaire FRS26R4CQD Frigidaire/refrigerator
Frigidaire FRS26R4CQE Frigidaire/refrigerator
Frigidaire FRS26R4CQS Frigidaire/refrigerator
Frigidaire FRS26R4CW0 Frigidaire/refrigerator
Frigidaire FRS26R4CW1 Frigidaire/refrigerator
Frigidaire FRS26R4CW2 Frigidaire/refrigerator
Frigidaire FRS26R4CW3 Frigidaire/refrigerator
Frigidaire FRS26R4CW4 Frigidaire/refrigerator
Frigidaire FRS26R4CW5 Frigidaire/refrigerator
Frigidaire FRS26R4CW6 Frigidaire/refrigerator
Frigidaire FRS26R4CW7 Frigidaire/refrigerator
Frigidaire FRS26R4CW8 Frigidaire/refrigerator
Frigidaire FRS26R4CW9 Frigidaire/refrigerator
Frigidaire FRS26R4CWA Frigidaire/refrigerator
Frigidaire FRS26R4CWB Frigidaire/refrigerator
Frigidaire FRS26R4CWC Frigidaire/refrigerator
Frigidaire FRS26R4CWD Frigidaire/refrigerator
Frigidaire FRS26R4CWE Frigidaire/refrigerator
Frigidaire FRS26R4CWR Frigidaire/refrigerator
Frigidaire FRS26R4CWS Frigidaire/refrigerator
Frigidaire FRS26RBBW0 Frigidaire/refrigerator
Frigidaire FRS26RBBW1 Frigidaire/refrigerator
Frigidaire FRS26RBCW0 Frigidaire/refrigerator
Frigidaire FRS26RBCW1 Frigidaire/refrigerator
Frigidaire FRS26RBCW2 Frigidaire/refrigerator
Frigidaire FRS26RBCW3 Frigidaire/refrigerator
Frigidaire FRS26RBCW4 Frigidaire/refrigerator
Frigidaire FRS26RBCW5 Frigidaire/refrigerator
Frigidaire FRS26RBCW6 Frigidaire/refrigerator
Frigidaire FRS26RBCW8 Frigidaire/refrigerator
Frigidaire FRS26RBCW9 Frigidaire/refrigerator
Frigidaire FRS26RBCWA Frigidaire/refrigerator
Frigidaire FRS26RLECS0 Frigidaire/refrigerator
Frigidaire FRS26RLECS1 Frigidaire/refrigerator
Frigidaire FRS26RLECS2 Frigidaire/refrigerator
Frigidaire FRS26RLECS3 Frigidaire/refrigerator
Frigidaire FRS26RLECS4 Frigidaire/refrigerator
Frigidaire FRS26RLECS6 Frigidaire/refrigerator
Frigidaire FRS26RLECS7 Frigidaire/refrigerator
Frigidaire FRS26RLECS8 Frigidaire/refrigerator
Frigidaire FRS26RLECS9 Frigidaire/refrigerator
Frigidaire FRS26RLECSA Frigidaire/refrigerator
Frigidaire FRS26RLECSB Frigidaire/refrigerator
Frigidaire FRS26RLECSC Frigidaire/refrigerator
Frigidaire FRS26RLECSE Frigidaire/refrigerator
Frigidaire FRS26RLECSF Frigidaire/refrigerator
Frigidaire FRS26RLECSG Frigidaire/refrigerator
Frigidaire FRS26RLECSH Frigidaire/refrigerator
Frigidaire FRS26RLECSN Frigidaire/refrigerator
Frigidaire FRS26RLECSP Frigidaire/refrigertor
Frigidaire FRS26RLECSR Frigidaire/refrigerator
Frigidaire FRS26RLECSS Frigidaire/refrigerator
Frigidaire FRS26RLECST Frigidaire/refrigerator
Frigidaire FRS26SM4AW0 Frigidaire/refrigerator
Frigidaire FRS26SM4AW2 Frigidaire/refrigerator
Frigidaire FRS26SM4AW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW1 Frigidaire/refrigerator
Frigidaire FRS26TS6DW2 Frigidaire/refrigerator
Frigidaire FRS26TS6DW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW5 Frigidaire/refrigerator
Frigidaire FRS26TS7DB0 Frigidaire/refrigerator
Frigidaire FRS26TS7DB1 Frigidaire/refrigerator
Frigidaire FRS26TS7DB2 Frigidaire/refrigerator
Frigidaire FRS26TS7DB3 Frigidaire/refrigerator
Frigidaire FRS26TS7DB5 Frigidaire/refrigerator
Frigidaire FRS26TS7DW0 Frigidaire/refrigerator
Frigidaire FRS26TS7DW1 Frigidaire/refrigerator
Frigidaire FRS26TS7DW2 Frigidaire/refrigerator
Frigidaire FRS26TS7DW3 Frigidaire/refrigerator
Frigidaire FRS26TS7DW5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ1 Frigidaire/refrigerator
Frigidaire FRS26W2AQ2 Frigidaire/refrigerator
Frigidaire FRS26W2AQ3 Frigidaire/refrigerator
Frigidaire FRS26W2AQ4 Frigidaire/refrigerator
Frigidaire FRS26W2AQ5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ6 Frigidaire/refrigerator
Frigidaire FRS26W2AQ7 Frigidaire/refrigerator
Frigidaire FRS26W2AQ8 Frigidaire/refrigerator
Frigidaire FRS26W2AQ9 Frigidaire/refrigerator
Frigidaire FRS26W2AQA Frigidaire/refrigerator
Frigidaire FRS26W2AQB Frigidaire/refrigerator
Frigidaire FRS26W2AQC Frigidaire/refrigerator
Frigidaire FRS26W2AQD Frigidaire/refrigerator
Frigidaire FRS26W2AQE Frigidaire/refrigerator
Frigidaire FRS26W2AW1 Frigidaire/refrigerator
Frigidaire FRS26W2AW2 Frigidaire/refrigerator
Frigidaire FRS26W2AW3 Frigidaire/refrigerator
Frigidaire FRS26W2AW4 Frigidaire/refrigerator
Frigidaire FRS26W2AW5 Frigidaire/refrigerator
Frigidaire FRS26W2AW6 Frigidaire/refrigerator
Frigidaire FRS26W2AW7 Frigidaire/refrigerator
Frigidaire FRS26W2AW8 Frigidaire/refrigerator
Frigidaire FRS26W2AW9 Frigidaire/refrigerator
Frigidaire FRS26W2AWA Frigidaire/refrigerator
Frigidaire FRS26W2AWB Frigidaire/refrigerator
Frigidaire FRS26W2AWC Frigidaire/refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer leaks water ed55 Refrigerator & Freezer Repair 0 05-01-2011 02:10 PM
Water leaks into ice maker, freezer when in-door water dispensed LostinLA Refrigerator & Freezer Repair 0 04-25-2011 06:09 PM
Water leaks into frigde from freezer kansascity.rita@gmail.com Refrigerator & Freezer Repair 0 07-14-2010 09:04 AM
freezer water leaks into the refrigerator. scohun Refrigerator & Freezer Repair 5 05-12-2009 09:22 AM
freezer leaks water kbowlby Refrigerator & Freezer Repair 1 07-06-2008 08:22 PM
