| » freezer leaks water |
Model Number: FRS26R4CB3 Brand: Frigidaire Age: 1 - 5 years
The freezer is leaking water around the drain tube and on to the floor. I cleaned the tube out and it did not help. It appears to be getting under the grommet inside and running down the outside of the tube underneath the refridgerator that goes to the pan. Is there supposed to be a space between the drip pan and the grommet on the drain tube, the holes do not seem to line up with each other causing the water to run down the side of the grommet and not go through the tube properly. But instead lays on the plastic bottom around the grommet and leaks under it and down the tube unto the floor. Any suggestions?
Thank you Ed Ads By Google Related Models |
| Display Modes | |
| Water leaks into ice maker, freezer when in-door water dispensed | LostinLA | Refrigerator & Freezer Repair | 0 | 04-25-2011 06:09 PM |
| Water leaks into frigde from freezer | kansascity.rita@gmail.com | Refrigerator & Freezer Repair | 0 | 07-14-2010 09:04 AM |
| Leaks water on floor in front of freezer | Recoop | Refrigerator & Freezer Repair | 2 | 11-21-2009 02:45 PM |
| freezer water leaks into the refrigerator. | scohun | Refrigerator & Freezer Repair | 5 | 05-12-2009 09:22 AM |
| freezer leaks water | kbowlby | Refrigerator & Freezer Repair | 1 | 07-06-2008 08:22 PM |
