jam-air brown
#1 Posted : Wednesday, January 21, 2009 8:57:06 AM(UTC)
jam-air brown
It sounds like the water pump humms but no water reaches the ice maker. This occurs on a regular cycling basis
kayakcrzy
#2 Posted : Thursday, January 22, 2009 4:17:06 AM(UTC)
kayakcrzy
First establish that you have water coming to the valve, and then second, you will want to check the water tube, where the water dumps into the ice maker and see if it is frozen up. If so replace the water valve, because it would be leaking a little water, enough to freeze the water tube. Tom
