My water dispenser and my icemaker were not working. So, I purchased a water inlet valve part number: AP4298908. I installed the valve and the water is still coming out of the dispenser or to the icemaker. I did work for about a day, but then quit. There are three relays on the valve. A brown one, a green one and a yellow one. The main valve, the brown one is getting voltage and when I remove the water hose from and press the water dispenser so I know that relay is working. When I remove the water hose from the yellow valve and press the water dispenser the yellow valve is energizing, but not water comes out of the valve. The same thing happens with the green relay, which is for the icemaker. My best guess is that I purchased a bad water inlet valve. Any other ideas?
