| » Amana bottom freezer buzzing/clicking, no defrost |
Model Number: arb2217CSL Brand: Amana Age: 5 - 10 years
Bottom freezer collecting frost on stored items.
Noise is click, buzz, relay click off. Suspect timer or heat coil? Know that timer is above refrigerator section behind light assembly, where is heat coil? Test procedures? Thank you most kindly for any advice Brian Ads By Google Related Models |
Quote:
That sounds more like a compressor relay or bad compressor. Defrost systems don't usually make clicking or buzzing noises, To access the heater and terminator, you'll need to remove everything inside the freezer, including the door and drawer rails on the walls, remove the screws holding the metal back wall to the cabinet, pull the panel out slowly and disconnect the wires from the fan motor, then remove the panel. you'll have access to the evaporator, defrost heater, and thermostat. You should move the unit out and isolate the noise, that way we know where to go from there.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Joe, Have back off refrig, and back panel out of freezer compartment. Heat coil is 30.2 ohms, thermostat tests open when warm. Buzz is definitely compressor. Cycles about every 2 1/2 minutes, and cycles on for about 10 seconds of buzzing, then clicks off. ???? |
Quote:
OK, so the heater and the thermostat check OK, Here's an easy way to test the compressor windings to determine if your compressor is bad or if you will need a start relay/overload assembly. Once you remove the cover off the side of the compressor, carefully remove the overload relay assembly. Part number: AP4013414 Test the compressor motor for continuity using a multitester. Set the multitester to the ohms setting X1. Place one [COLOR=#595959 !important][COLOR=#595959 !important]probe[/color][/color] on any terminal and then touch the other probe to each of the other two terminals. The multitester should display a reading of zero ohms. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multitester displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multitester still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multitester should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service. If all checks are proper, you'll need the relay assembly. Good Luck,
__________________
| Display Modes | |
| Kitchenaid bottom freezer humming/buzzing sound | nancylav | Refrigerator & Freezer Repair | 1 | 01-21-2011 02:53 AM |
| Amana bottom freezer defrost problem | gwetzler | Refrigerator & Freezer Repair | 2 | 11-18-2010 11:07 AM |
| Location of defrost timer? Amana BR18VL - Freezer on bottom. | virtualblues | Refrigerator & Freezer Repair | 5 | 07-06-2010 02:49 PM |
| Amana Bottom Freezer Refridgerator Defrost Issue | RycherGirl | Refrigerator & Freezer Repair | 1 | 11-11-2009 02:38 AM |
| Amana Bottom Freezer Defrost Cycle Help | harryhoudini | Refrigerator & Freezer Repair | 5 | 12-30-2008 08:07 PM |
