Ice Chute Door Stuck Open
Model Number: G56NBEXRS00 Brand: Whirlpool Age: 5 - 10 years
Having problems with my ice maker and have been having a lot of frost build up.
I noticed there was nothing stopping the air in my house from going right in my freezer. Poking around I found a flap stuck in the open position up under the inside of the chute area.
I found the replacement but I think there are motors and electronics happening here as well.
Any help on how to see if I can get it un stuck and working or if that does not work, what I would need to replace?
Thanks in advance.
Ads By Google
Related ModelsFrigidaire G5W Frigidaire G7W Maytag GA104 Washer - Top Loading Maytag GA107 Washer - Top Loading Maytag GA107S Washer - Top Loading Maytag GA108 Washer - Top Loading Maytag GA110 Washer - Top Loading Maytag GA1110PRW Range - F/s Std Gas Maytag GA112 Washer - Top Loading Maytag GA180 Washer - Top Loading Maytag GA183 Washer - Top Loading Maytag GA190 Washer - Top Loading Maytag GA1910 Washer - Top Loading Maytag GA200 Washer - Top Loading Maytag GA200S Washer - Top Loading Maytag GA202 Washer - Top Loading Maytag GA202S Washer - Top Loading Maytag GA203 Washer - Top Loading Maytag GA203S Washer - Top Loading Maytag GA206 Washer - Top Loading Maytag GA206S Washer - Top Loading Maytag GA208 Washer - Top Loading Maytag GA209 Washer - Top Loading Maytag GA210 Washer - Top Loading Maytag GA211 Washer - Top Loading Maytag GA211S Washer - Top Loading Maytag GA212 Washer - Top Loading Maytag GA212T Washer - Top Loading Maytag GA23CS Washer - Top Loading Maytag GA25CM Washer - Top Loading Maytag GA25CME Washer - Top Loading Maytag GA25CS Washer - Top Loading Maytag GA25CT Washer - Top Loading Maytag GA26CD Washer - Top Loading Maytag GA26CDC Washer - Top Loading Maytag GA282 Washer - Top Loading Maytag GA283 Washer - Top Loading Maytag GA284 Washer - Top Loading Maytag GA305 Washer - Top Loading Maytag GA308 Washer - Top Loading Maytag GA308S Washer - Top Loading Maytag GA310 Washer - Top Loading Maytag GA3110PRAM Range - F/s Std Gas Maytag GA3110PRWM Range - F/s Std Gas Maytag GA312 Washer - Top Loading International GA3170MPAW Range - F/s Std Gas International GA31713WAM Range - F/s Std Gas International GA31713WAV Range - F/s Std Gas International GA31713WAW Range - F/s Std Gas International GA3171SXAW Range - F/s Cont Clean Gas Maytag GA3177WUV Range - F/s Std Gas Maytag GA3177WUW5 Range - F/s Std Gas Maytag GA3216WRAM Range - F/s Std Gas Maytag GA3216WRWM Range - F/s Std Gas International GA3271SXAA Range - F/s Cont Clean Gas International GA3271SXAW Range - F/s Cont Clean Gas International GA3277WUAM Range - F/s Std Gas International GA3277WUWM Range - F/s Std Gas International GA3277XUA Range - F/s Std Gas International GA3277XUAM Range - F/s Std Gas International GA3277XUW Range - F/s Std Gas International GA3277XUWM Range - F/s Std Gas International GA3478XUAX Range - S/c F/s Gas International GA3478XUWX Range - S/c F/s Gas International GA3488VVV Range - S/c F/s Gas International GA3510PRW Range - F/s Std Ele International GA3531WUA Range - F/s Std Ele International GA3531WUV Range - F/s Std Ele International GA3531WUW Range - F/s Std Ele Maytag GA3631XUA Range - F/s Std Ele Maytag GA3631XUW Range - F/s Std Ele International GA3631XUWG Range - F/s Std Ele Maytag GA382 Washer - Top Loading Maytag GA382T Washer - Top Loading Maytag GA3872XUW Range - S/c F/s Ele International GA3878XUW Range - S/c F/s Ele Maytag GA390 Washer - Top Loading Maytag GA3910 Washer - Top Loading Maytag GA408 Washer - Top Loading Maytag GA408S Washer - Top Loading Maytag GA410 Washer - Top Loading Maytag GA412 Washer - Top Loading Maytag GA412T Washer - Top Loading International GA4251WTA Range - F/s Cont Clean Gas International GA4251WTW Range - F/s Cont Clean Gas Maytag GA482 Washer - Top Loading Maytag GA484 Washer - Top Loading Maytag GA490 Washer - Top Loading Maytag GA4910 Washer - Top Loading Maytag GA5000 Washer - Top Loading Maytag GA503 Washer - Top Loading Maytag GA506 Washer - Top Loading Maytag GA510 Washer - Top Loading Maytag GA512 Washer - Top Loading Maytag GA590 Washer - Top Loading Maytag GA5910 Washer - Top Loading Maytag GA608 Washer - Top Loading Maytag GA608S Washer - Top Loading Maytag GA610 Washer - Top Loading Maytag GA612 Washer - Top Loading Maytag GA612T Washer - Top Loading Maytag GA613 Washer - Top Loading Maytag GA6910 Washer - Top Loading Maytag GA710 Washer - Top Loading Maytag GA712 Washer - Top Loading Maytag GA7300 Washer - Top Loading Maytag GA7400 Washer - Top Loading Maytag GA7500 Washer - Top Loading Maytag GA7800 Washer - Top Loading Maytag GA806 Washer - Top Loading Maytag GA806S Washer - Top Loading Maytag GA810 Washer - Top Loading Maytag GA8100 Washer - Top Loading Maytag GA8120 Washer - Top Loading Maytag GA8140 Washer - Top Loading Maytag GA8200 Washer - Top Loading Maytag GA8210 Washer - Top Loading Maytag GA8240 Washer - Top Loading Maytag GA8340 Washer - Top Loading Maytag GA8420 Washer - Top Loading
