Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   bad contactor? (http://forum.appliancepartspros.com/refrigerator-freezer-repair/212553-bad-contactor.html)
bigdaddy01 04-27-2011 11:26 AM
bad contactor?
i have a whirlpool side by side refrigerator, model # ED25RFXN. hard to explain the problem. it is like the compressor is not turning on when it is supposed to. the unit has power, all the lights are on, water and ice dispensor work. just found it warm inside 2 or 3 times in the last month. unplugging it and plugging it back in do nothing. but,, if i turn the thermostat to the off position, then turn it back to the on position, it starts back up and runs fine. i live in a area with frequent power outages that only last 3 or 4 seconds. could a contactor be bad? thanks for your help.
richappy 04-29-2011 04:53 AM
Probably a bad cold control. Usually, if you tap on it when it fails, it will start working.
bigdaddy01 04-29-2011 05:07 AM
Quote:
the cold control ? . . . not quite sure what that would be ? .. .do you mean the on / off / thermostat switch ? . . . is it connected to a thermocouple somewhere ?:confused:
richappy 04-29-2011 06:04 AM
The control in back of the knob you turn to adjust the temperature.
bigdaddy01 04-29-2011 06:37 AM
Quote:
oh, o.k. i'll plug it back in and get it going again, and when it fails to work, i'll tap on it and see what happens. THANKS FOR THE TIP. at least if this works, i'll only have to buy one part, instead of buying parts i would just be guessing about. THANKS AGAIN :)
bigdaddy01 04-30-2011 06:20 AM
Quote:
:) :) :) THIS GUY WAS RIGHT ON THE MONEY. I CLOSED FRIDGE, PLUGGED IT IN, NOTHING. . . I TAPPED THE COLD CONTROL TWICE WITH THE HANDLE OF A SCREWDRIVER, AND FRIDGE FIRED RIGHT UP. . . . THANKS ALOT !!! . . . :) :) :)
richappy 04-30-2011 09:35 AM
You are welcome. You are lucky, I sometimes get ones that take one hour to trace down an intermittent.
