Discuss
Garage Freezer not freezing..part?
 in
Refrigerator & Freezer Repair
Hi Everyone, I need help to get my garage freezer to work. I live in chicago and understand that once
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Garage Freezer not freezing..part?
  #1 (permalink)
Old 01-19-2009, 06:52 AM
Junior Member
kev6873 is on a distinguished road
Default Garage Freezer not freezing..part?
Brand: Magic Chef   Age: 1 - 5 years
Hi Everyone,
I need help to get my garage freezer to work. I live in chicago and understand that once the temp around the fridge reaches 32, the freezer will stop working. What can i do to fix this? I was told I could use electric heat tape around the compressor to fool it into thinking its warmer. Guy at home depot said NOT to do this. I see the GE makes a repair kit for this sort of thing, but I have a Magic Chef and there is no part they make. Any ideas? thank you!!
  #2 (permalink)
Old 01-19-2009, 09:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
This may help
http://www.applianceaid.com/garage_fridge.html
First is it a freezer or a fridge. Further on you mention a fridge.
Also is it frost free?
From what I have found this is the kicker on fridges.
The unit goes into a defrost mode. This generates heat in the unit but because the ambient temp is low (the fridge section does not warm up) so the compressor does not start up after the defrost and everything in the freezer section partially melts.
Do not understand this. Both freezers and fridges do not monitor ambient temperature so I do not know what they think they are fooling.
If the problem is the compressor oil getting thick then this should work but you have to use the heat tape which has a temperature sensor built in (type used for copper pipes). Also where you place the sensor may be important you do not want to over heat the compressor. Do not know if you can get one that is short enough.
A battery blanket might also work, much lower heat output. Check to make sure that it has a thermostat built in. Some do, some don't.
Hopefully someone else has some better ideas.
__________________
  #3 (permalink)
Old 01-19-2009, 09:16 AM
Junior Member
Default Thanks...
It is a fridge with a freezer..so its both i guess. I have read that link and read all about this. What i dont understand is that GE makes a garage kit for theirs but I ahvent found anything for Magic Chef and was wondering if I could rig this another way...safely. If not, then i just dont use it in the winter and it becomes a spring, summer, fall fridge/freezer only.
  #4 (permalink)
Old 01-19-2009, 09:27 AM
Senior Expert
APP Volunteer
Default
Well I did find this for a Frigidaire, probably the same one you found.
Part Details - FRIGIDAIRE Garage kit, part number: AP3722172
But is says it is only good till down to 34 degrees.
__________________
  #5 (permalink)
Old 01-19-2009, 10:09 AM
Junior Member
Default Magic Chef
Yeah, I have a magic chef...would it work with that? how can you tell?
  #6 (permalink)
Old 01-19-2009, 03:15 PM
Senior Expert
APP Volunteer
Default
Sorry I cannot tell if it would work in a Magic Chef.
Looks like they are adding some heat to the thermostat area so it will cycle the compressor on/off this would work but it is a balancing act re: if too hot the unit would run continuously. You still have the problem of running the compressor in a freezing environment which is hard on it and greatly reduces it's ability to compress the freon/gas.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Refrigerator Garage Kit Part# squier3 Refrigerator & Freezer Repair 1 01-28-2010 05:45 AM
GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over jaxcarlson Refrigerator & Freezer Repair 0 12-01-2009 09:42 AM
Garage Freezer - dead after burnt electical michaelphughes Refrigerator & Freezer Repair 4 06-27-2009 01:10 PM
Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up badace Refrigerator & Freezer Repair 1 12-02-2007 09:54 AM
Freezer Part Of Frig Stopped Freezing ESETKO Refrigerator & Freezer Repair 2 10-04-2007 02:17 PM
