Discuss
Noise and Flickering Lights
 in
Refrigerator & Freezer Repair
I have a side by side that just started making a noise when the door is open. The lights are
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Noise and Flickering Lights
  #1 (permalink)
Old 01-18-2009, 05:54 AM
Junior Member
BrucenLynn is on a distinguished road
Default Noise and Flickering Lights
Brand: Whirlpool   Age: 5 - 10 years
I have a side by side that just started making a noise when the door is open. The lights are also flickering at a very low intensity, barely lighting the filaments. Unscrew the bulbs and the noise goes away. Sounds kind of like a relay hung up. I am comfortable working with electrical circuits. Any ideas? Everything else seems to be working fine.
  #2 (permalink)
Old 01-18-2009, 09:11 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
A model # will help know what you have. I was wondering if you have the model, that has the board in the bottom back next to the compressor. It is held in by two screws, and is inside of a white plastic case. Check it out. If not give us your model #. Tom ********************************************
  #3 (permalink)
Old 02-08-2009, 05:22 PM
Junior Member
CoachDave8503 is on a distinguished road
Default Same exact problem!
I have whirlpool side-by-side, Model GD55HAXZNQ00. Open the door one day and the light bulb was flickering at a low level and making a buzzing sound. I took the bulb out and the sound stopped. I thought is was bulb problem. I bought a new bulb, put it in, and it did the same thing? Any suggestions?
  #4 (permalink)
Old 02-01-2010, 08:33 AM
Junior Member
IowaBob is on a distinguished road
Default
I have Whirlpool side by side Fridge freezer model GS6SHEXNS00, which has the same problem. THE buzzing stops with bulbs removed. My post is number 179608. Other places, posts seem to indicate this happens when the Electronic Control Board needs to be replaced. The part is much cheaper from Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts.
I'll likely order the part today, does this sound right?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lights out in refrig side and clicking noise when door open hhixson Refrigerator & Freezer Repair 0 02-16-2010 05:27 PM
When Door Opens, Buzzing & Flickering Lights IowaBob Refrigerator & Freezer Repair 0 01-30-2010 04:03 PM
washer makes loud clicking noise & lights dim gregr25 Washer Repair 1 10-16-2009 06:01 PM
Won't run. has flickering Accusens & cataeyes Michael822 Dishwasher Repair 0 08-22-2009 01:48 PM
Agitator making knocking noise, house lights blinking. ksmiley Washer Repair 0 01-12-2009 09:57 AM
