| » Whirlpool Refrigerator Compressor runs not cooling |
Yes it looks like there is some confusion on these units.
See the attachment for a couple tech sheets. The ET0B seems to match if you look up the parts listing but ETA seems to match how your unit is wired. Since the compressor is running the unit should be cooling. Sounds like you have a sealed system problem. It could be the compressor itself, no freon or low on freon. Not that low on freon will usually give you some cooling just not enough. There will be some frost on part of the evaporator coils usually where the freon enters the coils from the compressor. I doubt you are stuck in a defrost cycle as the compressor and the fan would be off. I would check your warranty the sealed system may have a 5 year warranty. If you do not have you can downloads it from the Whirlpool website.
__________________
I cannot find the source of the leak but I did find the waranty as you said it may have and it is 5 years which I did not know so Thanks for letting me know! I am curious how it got to this state. I got it as a display model on sale at Lowes. I wonder looking back if it ever even cooled right.
I am curious about a couple things pre-service call. I don't want to be suprised when Whirpool sends out a tech and there is some reason they decide not to do the repairs or blame me. I wonder if there is a way to tell where the leak might be from visially? Is it possible to be low without having a leak? Is there a way to test/refill the units refrigerant? Or do they have to break into it, pressure test it and then recharge it after reparing a leak by some soldering process? The unit is outside under a covered area. Lot's of people use them this way but does it void a warranty in any way? I see the unit is weatherized somewhat at the base but the wiring looks good. Inside the fridge/freezer the parts are a bit corroded looking but things function normal except for the cooling it would seem from your response. Should I move the unit indoors for the service call or just leave it where it is? Thanks, Doug Last edited by i12flyskyhigh : 04-24-2011 at 09:03 AM. Reason: Mispelling |
I would doubt it. Is it possible to be low without having a leak? No unless it was low from day one. Is there a way to test/refill the units refrigerant? Or do they have to break into it, pressure test it and then recharge it after reparing a leak by some soldering process? The latter, you need a pro. The unit is outside does it void a warranty in any way? Not that I know of but probably depends where outside. If the unit is sitting out in the elements then that would probably void warranty. Should I move the unit indoors for the service call or just leave it where it is? Cannot really say but I would. You said that there is corrosion on the bottom that may well be a tip off to a repair tech that the unit was at one time outside. If the compressor etc. under the unit have gotten wet then that would void warranty. Often units will not run correctly outside if the temperature gets down to or below freezing. I do not think this is your problem because the compressor is running.
__________________
| Display Modes | |
| Refrigerator not cooling, fan working, compressor hot but not running | Andreyvol | Refrigerator & Freezer Repair | 52 | 04-05-2013 02:51 PM |
| GE sxs Refrigerator Runs but stopped Cooling | browndwz | Refrigerator & Freezer Repair | 7 | 09-13-2010 09:57 AM |
| Refrigerator not cooling/compressor making funny sound | koehler | Refrigerator & Freezer Repair | 4 | 04-10-2010 07:43 AM |
| Whirlpool fridge runs but not cooling | jdkelley | Refrigerator & Freezer Repair | 30 | 10-26-2009 05:04 AM |
| refridgerator not cooling but compressor runs | bpetska | Refrigerator & Freezer Repair | 3 | 06-16-2009 06:15 PM |
