Discuss
Do the evap.fans run all the time?
 in
Refrigerator & Freezer Repair
Looked at a Samsung RS2577SL trying to find out if the evap.fans should have been running with fridge powered up?I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Do the evap.fans run all the time?
  #1 (permalink)
Old 04-23-2011, 08:48 AM
Junior Member
ryan123 is on a distinguished road
Question Do the evap.fans run all the time?
Model Number: RS2577SL   Brand: Samsung   Age: 5 - 10 years
Looked at a Samsung RS2577SL trying to find out if the evap.fans should have been running with fridge powered up?I am thinking yes they should be running fulltime,unless in defrost.Fridge had been setting days with the compressor kicking out repeatedly on thermal.Compressor kicks out on thermal still checked cap. and within tolerence,and I am thinking maybe a fan or control board issue resulted in a frozen evap. which ultimately lead to the compressor lock up.The fans are DC controlled by the board.I tried to pin out the terminal at the board for voltage and didnt have voltage?Went across several didnt pin combos as not sure which pins to hit exactly.I had to be very cautious as not to short when checking either.Went according to sticker diagram on back.My probes wouldnt fit into the fan plug either to check there.Did not want to force and leave fridge worse than when I came.With the heavy electronics maybe the fans shut off for some other reason than defrost? Thanks for any help.
Related Models
 RS2577SL REF - SXS
 RS2577SW REF - SXS
 RS2578BB REF - SXS
 RS2578SH REF - SXS
 RS2578WW REF - SXS
 RS257BARB REF - SXS
Frigidaire RS259ESD1 Wwh(v1) / Side By Side Refrigerator
Frigidaire RS259ESD2 Wwh(v2) / Side By Side Refrigerator
Frigidaire RS259ESF1 Wwh(v3) / Side By Side Refrigerator
Frigidaire RS259ESF2 Wwh(v4) / Side By Side Refrigerator
Frigidaire RS259ESH1 Wwh(v5) / Side By Side Refrigerator
Frigidaire RS259ESH2 Wwh(v6) / Side By Side Refrigerator
Frigidaire RS259ESV1 Wwh(v7) / Side By Side Refrigerator
Frigidaire RS259ESV2 Wwh(v8) / Side By Side Refrigerator
Frigidaire RS259ESW1 Wwh(v9) / Side By Side Refrigerator
Frigidaire RS259ESW2 Wwh(v10) / Side By Side Refrigerator
Roper RS25AEXLQ00 REFRIGERATOR
Roper RS25AFXMQ00 REFRIGERATOR
Roper RS25AFXRD01 REFRIGERATOR
Roper RS25AFXRD02 REFRIGERATOR
Roper RS25AGXNQ00 REFRIGERATOR
Roper RS25AGXNQ01 REFRIGERATOR
Roper RS25AGXNQ02 REFRIGERATOR
Roper RS25AQXFN00 REFRIGERATOR
Roper RS25AQXFN01 REFRIGERATORS
Roper RS25AQXFN02 REFRIGERATOR
Roper RS25AQXFW00 REFRIGERATOR
Roper RS25AQXFW01 REFRIGERATORS
Roper RS25AQXFW02 REFRIGERATOR
Roper RS25AQXGN00 REFRIGERATOR
Roper RS25AQXGN01 REFRIGERATOR
Roper RS25AQXGN02 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AQXGW00 REFRIGERATOR
Roper RS25AQXGW01 REFRIGERATOR
Roper RS25AQXGW02 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXAW00 Refrigerators*
Roper RS25AWXBL00 REFRIGERATOR
Roper RS25AWXBN01 REFRIGERATOR
Roper RS25AWXBW00 REFRIGERATOR
Roper RS25AWXBW01 REFRIGERATOR
Roper RS25AWXDN00 REFRIGERATOR
Roper RS25AWXDW00 REFRIGERATOR
Roper RS25AWXEN00 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXEN01 REFRIGERATOR
Roper RS25AWXEW00 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXEW01 REFRIGERATOR
Roper RS25AWXVW00 Refrigerators*
Roper RS25AWXVW02 Refrigerators*
Roper RS25AWXWL00 REFRIGERATOR
Roper RS25AWXWW00 REFRIGERATOR
Roper RS25AWXXW00 Refrigerators*
Roper RS25AWXZW00 Refrigerators*
Whirlpool RS25AWXZW01 Refrigerators*
Roper RS25CFXTQ00 REFRIGERATOR
Roper RS25CFXTQ01 REFRIGERATOR
Roper RS25CGXTD00 REFRIGERATOR
 RS2621SW REF - SXS
 RS2622SW REF - SXS
 RS2622SW/XAA REF - SXS
 RS2623BB REF - SXS
 RS2623SH REF - SXS
 RS2623SL REF - SXS
 RS2623VQ REF - SXS
 RS2623WW REF - SXS
 RS2624WW/XAA REF - SXS
 RS2630SH REF - SXS
 RS2630SH/XAA REF - SXS
 RS2630WW REF - SXS
 RS2630WW/XAA REF - SXS
 RS2644SL REF - SXS
 RS2644SW REF - SXS
 RS265LABP REF - SXS
 RS265LAWP REF - SXS
 RS2666SL REF - SXS
 RS2666SW REF - SXS
 RS267LABP REF - SXS
 RS267LABP/XAA REF - SXS
 RS267LASH REF - SXS
 RS267LASH/XAA REF - SXS
 RS269LARS REF - SXS
 RS2777SL REF - SXS
Hoover RS27D011 REF - SXS/I&W
Amana RS30 MWAVE- CNTRTP / STAND ALONE
Whirlpool RS3025XBN0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBN1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS3025XBW0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBW1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXBH0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS310PXEB0 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXEB1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXGN0 ELECTRIC RANGE
Whirlpool RS310PXGW0 ELECTRIC RANGE
Whirlpool RS313PXTT0 Ranges, Electric*
Whirlpool RS313PXYH0 Ranges, Electric*
Whirlpool RS313PXYH2 Ranges, Electric*
Whirlpool RS333PXTT0 Ranges, Electric
Frigidaire RS33BFL0 Frg(v2) / Electric Range
Frigidaire RS33BFL1 Frg(v4) / Electric Range
Frigidaire RS33BFL2 Frg(v2) / Electric Range
Frigidaire RS33BFW0 Frg(v1) / Electric Range
Frigidaire RS33BFW1 Frg(v3) / Electric Range
Frigidaire RS33BFW2 Frg(v1) / Electric Range
Frigidaire RS33BNL1 Frg(v2) / Electric Range
Frigidaire RS33BNL2 Frg(v2) / Electric Range
Frigidaire RS33BNL3 Frg(v2) / Electric Range
Frigidaire RS33BNW1 Frg(v1) / Electric Range
Frigidaire RS33BNW2 Frg(v1) / Electric Range
Frigidaire RS33BNW3 Frg(v1) / Electric Range
Frigidaire RS34BFL0 Frg(v2) / Electric Range
Frigidaire RS34BFL1 Frg(v4) / Electric Range
Frigidaire RS34BFL2 Frg(v2) / Electric Range
Frigidaire RS34BFW0 Frg(v1) / Electric Range
Frigidaire RS34BFW1 Frg(v3) / Electric Range
Frigidaire RS34BFW2 Frg(v1) / Electric Range
Frigidaire RS35BAA2 Frg(v4) / Electric Range
Frigidaire RS35BAA3 Frg(v9) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fans Run Constantly Binhammer Refrigerator & Freezer Repair 0 06-22-2009 07:29 PM
cooling fans run long time Blake1111 Oven Repair (including Ranges and Cooktops) 3 06-25-2008 02:57 PM
Fans not Working BGhar Refrigerator & Freezer Repair 0 07-31-2007 08:59 PM
