Ice maker worked for a day, half-filled the bin, and then I heard water pouring into the freezer compartment. I shut it off, and checked the dual inlet valve. Tapped on it, re-installed, and the water measured into the ice maker and made ice for three cycles, then quit working. The LED is working. The water dispenser is working. In an earlier post, it said to check for power coming into the valve from the ice maker. Where at on the valve? And, what will it read in voltage or amps with a DMM if there is a problem. What is the fix?
