Discuss
refrigerator too warm
 in
Refrigerator & Freezer Repair
Refrigerator not cooling. Freezer freezing fine. Possible fixes please. Ads By Google Related Models Amana  ARB2205CW  Ref - Bottom Mounts
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator too warm
  #1 (permalink)
Old 04-18-2011, 01:46 PM
Junior Member
Julie KP is on a distinguished road
Default refrigerator too warm
Model Number: ARB2205CW   Brand: Amana   Age: 5 - 10 years
Ads By Google
Related Models
Amana ARB220RCB  Ref - Bottom Mounts
Amana ARB220RCC  Ref - Bottom Mounts
Amana ARB220RCW  Ref - Bottom Mounts
Amana ARB220ZCB  Ref - Bottom Mounts
Amana ARB220ZCC  Ref - Bottom Mounts
Amana ARB220ZCS  Ref - Bottom Mounts
Amana ARB220ZCW  Ref - Bottom Mounts
Amana ARB2214CB  Ref - Bottom Mounts
Amana ARB2214CC  Ref - Bottom Mounts
Amana ARB2214CSL  Ref - Bottom Mounts
Amana ARB2214CSR  Ref - Bottom Mounts
Amana ARB2214CW  Ref - Bottom Mounts
Amana ARB2217CB  Ref - Bottom Mounts
Amana ARB2217CC  Ref - Bottom Mounts
Amana ARB2217CSL  Ref - Bottom Mounts
Amana ARB2217CSR Ref - Bottom Mounts
Amana ARB2217CW  Ref - Bottom Mounts
Amana ARB224RCB  Ref - Bottom Mounts
Amana ARB224RCC  Ref - Bottom Mounts
Amana ARB224RCW  Ref - Bottom Mounts
Amana ARB2257CB  Ref - Bottom Mounts
Amana ARB2257CC  Ref - Bottom Mounts
Amana ARB2257CSL  Ref - Bottom Mounts
Amana ARB2257CSR  Ref - Bottom Mounts
Amana ARB2257CW  Ref - Bottom Mounts
Amana ARB2259CB  Ref - Bottom Mounts
Amana ARB2259CC  Ref - Bottom Mounts
Amana ARB2259CS  Ref - Bottom Mounts
Amana ARB2259CW  Ref - Bottom Mounts
Amana ARB2517CB  Ref - Bottom Mounts
Amana ARB2517CC  Ref - Bottom Mounts
Amana ARB2517CSL  Ref - Bottom Mounts
Amana ARB2517CSR  Ref - Bottom Mounts
Amana ARB2517CW  Ref - Bottom Mounts
Amana ARB2557CB  Ref - Bottom Mounts
Amana ARB2557CC  Ref - Bottom Mounts
Amana ARB2557CSL  Ref - Bottom Mounts
Amana ARB2557CSR  Ref - Bottom Mounts
Amana ARB2557CW  Ref - Bottom Mounts
Amana ARB8057CB  Ref - Bottom Mounts
Amana ARB8057CC  Ref - Bottom Mounts
Amana ARB8057CSL  Ref - Bottom Mounts
Amana ARB8057CSR  Ref - Bottom Mounts
Amana ARB8057CW  Ref - Bottom Mounts
Amana ARB9058CB  Ref - Bottom Mounts
Amana ARB9058CS  Ref - Bottom Mounts
Amana ARB9058CW  Ref - Bottom Mounts
Amana ARB9059CS  Ref - Bottom Mounts
Amana ARC-1 Range - S/c S/i Ddraft Gas
Amana ARC-100 Range - S/c S/i Ddraft Gas
Amana ARC-100B Range - S/c S/i Ddraft Gas
Amana ARC-1B Range - S/c S/i Ddraft Gas
Amana ARC-2 Range - S/c S/i Ddraft Gas
Amana ARC-2B Range - S/c S/i Ddraft Gas
Amana ARC-506 Range - S/c S/i Ddraft Ele
Amana ARC100B Range - S/c S/i Ddraft Ele
Amana ARC100D Range - S/c S/i Ddraft Ele
Amana ARC1B Range - S/c S/i Ddraft Ele
Amana ARC502W Range - S/c S/i Ddraft Ele
Amana ARC505 Range - S/c F/s Ele
Amana ARC505B Range - S/c S/i Ddraft Ele
Amana ARC515 Range - S/c S/i Ddraft Ele
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700LL Range - S/c S/i Ddraft Ele
Amana ARC700WW Range - S/c S/i Ddraft Ele
Amana ARDS800E Range - S/c S/i Ddraft Ele
Amana ARDS800WW Range - S/c S/i Ddraft Ele
Amana ARDS801E Range - S/c S/i Ddraft Ele
Amana ARDS801WW Range - S/c S/i Ddraft Ele
Amana ARDS802E Range - S/c S/i Ddraft Ele
Amana ARDS802SS Range - S/c S/i Ddraft Ele
Amana ARDS802WW Range - S/c S/i Ddraft Ele
Amana ARE14 Misc / Accessory
Amana ARE640 Range - S/c S/i Ddraft Gas
Amana ARE650 Range - S/c S/i Ddraft Gas
Amana ARG3600L Range - S/i Std Gas
Amana ARG3600LL Range - S/c S/i Ddraft Gas
Amana ARG3600W Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 04-19-2011, 05:46 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for AMANA ARB2205CW REF - BOTTOM MOUNTS | AppliancePartsPros.com
Is the fan in the freezer running. It is required to blow cold air into the fresh food section.
If the unit has a freezer door switch you may have to close this to get the fan on.
I would check the freezer temperature, it should be around 0 to 5 degrees F.
Sometimes the food will still be frozen (under 32 degrees F) but it is not cold enough to cool the fresh food side properly.
Check that the damper (Item 18 in Section 3) is open. This is what actually regulates the amount of cold air entering the fresh food area. If you click on it's picture you will get a better view. You will see that it has it's own thermostat which opens/closes the louvers.
If all OK remove the cover from inside the freezer so you can see the coils, you may have the early signs of a defrost problem.
If the coils are heavily iced/frosted over you have a defrost problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is too warm that ice cream is melted and Refrigerator is too warm too vegascyclist Refrigerator & Freezer Repair 6 05-06-2011 06:59 AM
Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm 808BigShorty Refrigerator & Freezer Repair 2 02-23-2011 01:04 PM
refrigerator making loud revving engine noise and now feels warm in refrigerator part tallulah Refrigerator & Freezer Repair 0 02-06-2011 07:15 AM
Moved refrigerator, freezer fine but refrigerator is too warm tigerjim Refrigerator & Freezer Repair 1 06-09-2010 10:59 AM
GE Profile refrigerator-warm freezer & refrigerator ykim4492 Refrigerator & Freezer Repair 2 02-14-2010 05:52 PM
