Freezer bed filled with ice
Refrigerator & Freezer Repair
I do not have the icemaker hooked up. The freezer's temperature is okay. But, I am getting condensation building up
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer bed filled with ice
  #1 (permalink)
Old 04-16-2011, 01:48 PM
Junior Member
lindahill is on a distinguished road
Unhappy Freezer bed filled with ice
Model Number: 795.73262300   Brand: Kenmore   Age: 5 - 10 years
I do not have the icemaker hooked up. The freezer's temperature is okay. But, I am getting condensation building up as ice on the deck of the freezer and it is thick. Every so often it will leak down into the refrigerator part. What is wrong? Could it be a fan problem?
Related Models
Kenmore 79531002700 REFRIGERATOR
Kenmore 79531006700 REFRIGERATOR
Kenmore 79539113600 SIDE-BY-SIDE
Kenmore 79551012010 REFRIGERATOR
Kenmore 79551012011 REFRIGERATOR
Kenmore 79551012012 REFRIGERATOR
Kenmore 79551013010 REFRIGERATOR
Kenmore 79551013011 REFRIGERATOR
Kenmore 79551013012 REFRIGERATOR
Kenmore 79551014010 REFRIGERATOR
Kenmore 79551014011 REFRIGERATOR
Kenmore 79551014012 REFRIGERATOR
Kenmore 79551016010 REFRIGERATOR
Kenmore 79551016011 REFRIGERATOR
Kenmore 79551016012 REFRIGERATOR
Kenmore 79551019010 REFRIGERATOR
Kenmore 79551019011 REFRIGERATOR
Kenmore 79551019012 REFRIGERATOR
Kenmore 79551022010 REFRIGERATOR
Kenmore 79551022011 REFRIGERATOR
Kenmore 79551022012 REFRIGERATOR
Kenmore 79551023010 REFRIGERATOR
Kenmore 79551023011 REFRIGERATOR
Kenmore 79551023012 REFRIGERATOR
Kenmore 79551024010 REFRIGERATOR
Kenmore 79551024011 REFRIGERATOR
Kenmore 79551024012 REFRIGERATOR
Kenmore 79551026010 REFRIGERATOR
Kenmore 79551026011 REFRIGERATOR
Kenmore 79551026012 REFRIGERATOR
Kenmore 79551029010 REFRIGERATOR
Kenmore 79551029011 REFRIGERATOR
Kenmore 79551029012 REFRIGERATOR
Kenmore 79551032010 REFRIGERATOR
Kenmore 79551032011 REFRIGERATOR
Kenmore 79551033010 REFRIGERATOR
Kenmore 79551033011 REFRIGERATOR
Kenmore 79551034010 REFRIGERATOR
Kenmore 79551034011 REFRIGERATOR
Kenmore 79551036010 REFRIGERATOR
Kenmore 79551036011 REFRIGERATOR
Kenmore 79551039010 REFRIGERATOR
Kenmore 79551039011 REFRIGERATOR
Kenmore 79551072010 REFRIGERATOR
Kenmore 79551072011 REFRIGERATOR
Kenmore 79551073010 REFRIGERATOR
Kenmore 79551073011 REFRIGERATOR
Kenmore 79551074010 REFRIGERATOR
Kenmore 79551074011 REFRIGERATOR
Kenmore 79551076010 REFRIGERATOR
Kenmore 79551076011 REFRIGERATOR
Kenmore 79551079010 REFRIGERATOR
Kenmore 79551079011 REFRIGERATOR
Kenmore 79551082010 REFRIGERATOR
Kenmore 79551082011 REFRIGERATOR
Kenmore 79551083010 REFRIGERATOR
Kenmore 79551083011 REFRIGERATOR
Kenmore 79551086010 REFRIGERATOR
Kenmore 79551086011 REFRIGERATOR
Kenmore 79551089010 REFRIGERATOR
Kenmore 79551089011 REFRIGERATOR
Kenmore 79551092010 REFRIGERATOR
Kenmore 79551092011 REFRIGERATOR
Kenmore 79551093010 REFRIGERATOR
Kenmore 79551093011 REFRIGERATOR
Kenmore 79551099010 REFRIGERATOR
Kenmore 79551099011 REFRIGERATOR
Kenmore 79551312010 REFRIGERATOR
Kenmore 79551312011 REFRIGERATOR
Kenmore 79551312012 REFRIGERATOR
Kenmore 79551313010 REFRIGERATOR
Kenmore 79551313011 REFRIGERATOR
Kenmore 79551313012 REFRIGERATOR
Kenmore 79551314010 REFRIGERATOR
Kenmore 79551314011 REFRIGERATOR
Kenmore 79551314012 REFRIGERATOR
Kenmore 79551316010 REFRIGERATOR
Kenmore 79551316011 REFRIGERATOR
Kenmore 79551316012 REFRIGERATOR
Kenmore 79551319010 REFRIGERATOR
Kenmore 79551319011 REFRIGERATOR
Kenmore 79551319012 REFRIGERATOR
Kenmore 79551322010 REFRIGERATOR
Kenmore 79551322011 REFRIGERATOR
Kenmore 79551322012 REFRIGERATOR
Kenmore 79551323010 REFRIGERATOR
Kenmore 79551323011 REFRIGERATOR
Kenmore 79551326010 REFRIGERATOR
Kenmore 79551326011 REFRIGERATOR
Kenmore 79551329010 REFRIGERATOR
Kenmore 79551329011 REFRIGERATOR
Kenmore 79551329012 REFRIGERATOR
Kenmore 79551372010 REFRIGERATOR
Kenmore 79551373010 REFRIGERATOR
Kenmore 79551374010 REFRIGERATOR
Kenmore 79551376010 REFRIGERATOR
Kenmore 79551379010 REFRIGERATOR
Kenmore 79558812900 REFRIGERATOR
Kenmore 79558813900 REFRIGERATOR
Kenmore 79558814900 REFRIGERATOR
Kenmore 79558814901 REFRIGERATOR
Kenmore 79558816900 REFRIGERATOR
Kenmore 79558819900 REFRIGERATOR
Kenmore 79558819901 REFRIGERATOR
Kenmore 79558822900 REFRIGERATOR
Kenmore 79558823900 REFRIGERATOR
Kenmore 79558826900 REFRIGERATOR
Kenmore 79558829900 REFRIGERATOR
Kenmore 79565002400 REFRIGERATOR
Kenmore 79565002401 BOTTOM-MOUNT
Kenmore 79565004400 REFRIGERATOR
Kenmore 79565004401 BOTTOM-MOUNT
Kenmore 79565004402 REFRIGERATOR
Kenmore 79565009400 REFRIGERATOR
Kenmore 79565009401 BOTTOM-MOUNT
Kenmore 79565012400 REFRIGERATOR
Kenmore 79565012401 BOTTOM-MOUNT
Kenmore 79565014400 REFRIGERATOR
Kenmore 79565014401 BOTTOM-MOUNT
  #2 (permalink)
Old 04-17-2011, 04:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Sounds like it is plugged so that the water from the defrost cycle cannot drain into the drain pan.
I wold check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that you do not overflow your drip tray.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer filled now won't do anything skp799 Washer Repair 1 12-14-2010 11:22 AM
Water not shuttig off once filled. rojr3 Washer Repair 1 02-21-2010 05:33 PM
Water too much filled in ice maker Jin Refrigerator & Freezer Repair 1 04-27-2009 12:29 PM
Washer filled up and thats all she wrote Craig S Washer Repair 0 12-28-2008 06:07 PM
Filled will not go to cycle Csugarbrown9122 Washer Repair 1 01-23-2008 03:39 AM
