Discuss
Amana compressor motor will not start
 in
Refrigerator & Freezer Repair
I have read through many posts with similar problems. The freezer and fridge compartments will not cool. Compressor relay tries
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana compressor motor will not start
  #1 (permalink)
Old 04-15-2011, 12:48 PM
Junior Member
blinkedty is on a distinguished road
Default Amana compressor motor will not start
Model Number: ARB2217CW0   Brand: Amana   Age: 5 - 10 years
I have read through many posts with similar problems. The freezer and fridge compartments will not cool. Compressor relay tries to start motor, then clicks off. I replaced the relay and overload protector, hoping that would be the problem, but to no avail.
So, next, I pulled out the multimeter. I removed the relay from the side of the compressor housing and tested each prong on the compressor. Each pair tested at zero ohms. I also tested to see if there was continuity between the prongs and the housing, but the ohm reading was infinity. I scraped off the paint to get down to bare metal on the housing.
From what I have read, these tests indicate that the motor is OK. Am I missing something? Is there something else which would keep the motor from starting?
If the compressor is bad, replacing it would almost be equivalent to a new unit.
I sure appreciate all the information that experts post on the internet. How did we ever do home repairs without the net? But I DO know when to call in an expert.
By the way, all the fans seem to be working.
Any ideas? Thanks
Related Models
Amana ARB224RCB REF - BOTTOM MOUNTS
Amana ARB224RCC REF - BOTTOM MOUNTS
Amana ARB224RCW REF - BOTTOM MOUNTS
Amana ARB2257CB REF - BOTTOM MOUNTS
Amana ARB2257CC REF - BOTTOM MOUNTS
Amana ARB2257CSL REF - BOTTOM MOUNTS
Amana ARB2257CSR REF - BOTTOM MOUNTS
Amana ARB2257CW REF - BOTTOM MOUNTS
Amana ARB2259CB REF - BOTTOM MOUNTS
Amana ARB2259CC REF - BOTTOM MOUNTS
Amana ARB2259CS REF - BOTTOM MOUNTS
Amana ARB2259CW REF - BOTTOM MOUNTS
Amana ARB2517CB REF - BOTTOM MOUNTS
Amana ARB2517CC REF - BOTTOM MOUNTS
Amana ARB2517CSL REF - BOTTOM MOUNTS
Amana ARB2517CSR REF - BOTTOM MOUNTS
Amana ARB2517CW REF - BOTTOM MOUNTS
Amana ARB2557CB REF - BOTTOM MOUNTS
Amana ARB2557CC REF - BOTTOM MOUNTS
Amana ARB2557CSL REF - BOTTOM MOUNTS
Amana ARB2557CSR REF - BOTTOM MOUNTS
Amana ARB2557CW REF - BOTTOM MOUNTS
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
Amana ARE640 RANGE- S/C S/I DDRAFT GAS
Amana ARE640 RANGE- S/C S/I DDRAFT ELE
Amana ARE650 RANGE- S/C S/I DDRAFT GAS
Amana ARE650 RANGE- S/C S/I DDRAFT ELE
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3600W RANGE- S/C S/I DDRAFT GAS
Amana ARG3600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG3601L RANGE- S/C S/I DDRAFT GAS
Amana ARG3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3601W RANGE- S/C S/I DDRAFT GAS
Amana ARG3601WW RANGE- S/C S/I DDRAFT GAS
Whirlpool ARG483WP01 Refrigerators*
Whirlpool ARG490 REFRIGERATOR
Whirlpool ARG4901 SIDE-BY-SIDE REFRIGERATOR
Amana ARG7102C RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 04-16-2011, 06:50 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for ARB2217CW0 models | AppliancePartsPros.com
Use a more sensitive ohms scale.
Zero ohms just tells you that there is continuity but they may be shorted to each other internally.
Here is a good link with testing info.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Could be the capacitor but it is hard to really test then as they should be tested using operating voltage but the meter should at least tell you if it is open or shorted at the meters voltage. My understanding is that the capacitors rarely need replacing.
Even if the compressor checks out OK electrically it may still be toast as it may have mechanical problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana refrigerator compressor seizing. richappy Refrigerator & Freezer Repair 1 08-23-2009 09:12 AM
Replacing compressor Amana Lawrence430 Refrigerator & Freezer Repair 3 05-15-2009 05:21 PM
Amana dimensions compressor kicks off Legend in Your Mind Refrigerator & Freezer Repair 0 04-25-2009 02:15 PM
Motor next to Compressor burnt - Amana Side by Side Refrigerator hlitebrite Refrigerator & Freezer Repair 4 03-03-2009 08:49 AM
Amana #341 compressor msl Refrigerator & Freezer Repair 1 10-09-2008 09:49 AM
