Discuss
Refrigerator evaporator fan not turning on
 in
Refrigerator & Freezer Repair
Hi, I have a KithchenAid KSCS25FKSS00 side by side refrigerator. The lower freezer area was cold, but the upper freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator evaporator fan not turning on
  #1 (permalink)
Old 04-14-2011, 08:04 AM
Junior Member
jsteely is on a distinguished road
Question Refrigerator evaporator fan not turning on
Model Number: KSCS25FKSS00   Brand: Kitchen Aid   Age: 5 - 10 years
Hi, I have a KithchenAid KSCS25FKSS00 side by side refrigerator. The lower freezer area was cold, but the upper freezer and refrigerator sections were warm, so I investigated.
The compressor runs fine (pretty much constantly now) and the evaporator coils frost over. Occassionally it seems to go into a defrost cycle and melt the ice.
I checked the voltage to the evaporator fan.
- Yellow to White was 3 volts (should be 5-17v I read somewhere)
- Red to White was 12 volts (which it should be)
I figured my $8 test tool was just off a little, so I was about to replace the fan, but before doing so, I ran a little test.
I pulled the evaporator fan from the freezer and using a 9 volt battery put 9v accross the yellow and white as well as the red and white terminals and the fan started to spin immediately.
So now I believe that the fan is fine, and something is wrong with the voltages coming in on the harness. Possibly the 3v input is too low or maybe something else?
What would cause the input voltage to be low (3v vs. 5-17v) and the evaporator motor to never turn on? Everything else seems to be ok.
If there are multiple possible causes, how would I test to confirm which component has failed?
Additonal info:
I found a guide on running the Electronic Control Tests from the key pad in the fridge.
Step 03 result was a red light indicating "Evaporator Fan Moter ON / Improper Speed"
Step 05 was also red indicating "VC Compressor OFF, waiting for min off delay" - which makes sense, since the compressor had been running just before I started the test.
The 5 other tests were all green (Freezer thermistor, frige thermistor, condensor fan motor on, air door opens & closes, and Heater energized/bimetal closed)
Thanks!
John
Related Models
Whirlpool KSCS25FKSS00 REFRIGERATOR
Whirlpool KSCS25FKSS01 REFRIGERATOR
Whirlpool KSCS25FKSS02 REFRIGERATOR
Whirlpool KSCS25FKWH01 REFRIGERATOR
Whirlpool KSCS25FKWH02 REFRIGERATOR
Whirlpool KSCS25FSBL00 REFRIGERATOR
Whirlpool KSCS25FSBL01 REFRIGERATOR
Whirlpool KSCS25FSBL02 REFRIGERATOR
Whirlpool KSCS25FSBL03 REFRIGERATOR
Whirlpool KSCS25FSBT00 REFRIGERATOR
Whirlpool KSCS25FSBT01 REFRIGERATOR
Whirlpool KSCS25FSBT02 REFRIGERATOR
Whirlpool KSCS25FSBT03 REFRIGERATOR
Whirlpool KSCS25FSMS00 REFRIGERATOR
Whirlpool KSCS25FSMS01 REFRIGERATOR
Whirlpool KSCS25FSMS02 REFRIGERATOR
Whirlpool KSCS25FSMS03 REFRIGERATOR
Whirlpool KSCS25FSSS01 REFRIGERATOR
Whirlpool KSCS25FSSS02 REFRIGERATOR
Whirlpool KSCS25FSSS03 REFRIGERATOR
Whirlpool KSCS25FSWH00 REFRIGERATOR
Whirlpool KSCS25FSWH01 REFRIGERATOR
Whirlpool KSCS25FSWH02 REFRIGERATOR
Whirlpool KSCS25FSWH03 REFRIGERATOR
Whirlpool KSCS25FTBL00 REFRIGERATOR
Whirlpool KSCS25FTBL01 REFRIGERATOR
Whirlpool KSCS25FTBL02 REFRIGERATOR
Whirlpool KSCS25FTBT00 REFRIGERATOR
Whirlpool KSCS25FTBT01 REFRIGERATOR
Whirlpool KSCS25FTBT02 REFRIGERATOR
Whirlpool KSCS25FTMK00 REFRIGERATOR
Whirlpool KSCS25FTMK01 REFRIGERATOR
Whirlpool KSCS25FTMK02 REFRIGERATOR
Whirlpool KSCS25FTMS00 REFRIGERATOR
Whirlpool KSCS25FTMS01 REFRIGERATOR
Whirlpool KSCS25FTMS02 REFRIGERATOR
Whirlpool KSCS25FTSS00 REFRIGERATOR
Whirlpool KSCS25FTSS01 REFRIGERATOR
Whirlpool KSCS25FTSS02 REFRIGERATOR
Whirlpool KSCS25FTWH00 REFRIGERATOR
Whirlpool KSCS25FTWH01 REFRIGERATOR
Whirlpool KSCS25FTWH02 REFRIGERATOR
Whirlpool KSCS25FVBL00 REFRIGERATOR
Whirlpool KSCS25FVBL01 REFRIGERATOR
Whirlpool KSCS25FVBL02 REFRIGERATOR
KitchenAid KSCS25FVBL03 REFRIGERATOR
Whirlpool KSCS25FVBT00 REFRIGERATOR
Whirlpool KSCS25FVBT01 REFRIGERATOR
Whirlpool KSCS25FVBT02 REFRIGERATOR
KitchenAid KSCS25FVBT03 REFRIGERATOR
Whirlpool KSCS25FVMK00 REFRIGERATOR
Whirlpool KSCS25FVMK01 REFRIGERATOR
Whirlpool KSCS25FVMK02 REFRIGERATOR
KitchenAid KSCS25FVMK03 REFRIGERATOR
Whirlpool KSCS25FVMS00 REFRIGERATOR
Whirlpool KSCS25FVMS01 REFRIGERATOR
Whirlpool KSCS25FVMS02 REFRIGERATOR
KitchenAid KSCS25FVMS03 REFRIGERATOR
Whirlpool KSCS25FVSS00 REFRIGERATOR
Whirlpool KSCS25FVSS01 REFRIGERATOR
Whirlpool KSCS25FVSS02 REFRIGERATOR
KitchenAid KSCS25FVSS03 REFRIGERATOR
Whirlpool KSCS25FVWH00 REFRIGERATOR
Whirlpool KSCS25FVWH01 REFRIGERATOR
Whirlpool KSCS25FVWH02 REFRIGERATOR
KitchenAid KSCS25FVWH03 REFRIGERATOR
Whirlpool KSCS25INBL00 REFRIGERATOR
Whirlpool KSCS25INBL01 REFRIGERATOR
Whirlpool KSCS25INBL02 REFRIGERATOR
Whirlpool KSCS25INBL03 REFRIGERATOR
Whirlpool KSCS25INBT00 REFRIGERATOR
Whirlpool KSCS25INBT01 REFRIGERATOR
Whirlpool KSCS25INBT02 REFRIGERATOR
Whirlpool KSCS25INBT03 REFRIGERATOR
KitchenAid KSCS25INMS00 SXS
Whirlpool KSCS25INMS01 REFRIGERATOR
Whirlpool KSCS25INMS02 REFRIGERATOR
Whirlpool KSCS25INMS03 REFRIGERATOR
Whirlpool KSCS25INSS00 REFRIGERATOR
Whirlpool KSCS25INSS01 REFRIGERATOR
Whirlpool KSCS25INSS02 REFRIGERATOR
Whirlpool KSCS25INSS03 REFRIGERATOR
Whirlpool KSCS25INWH00 REFRIGERATOR
Whirlpool KSCS25INWH01 REFRIGERATOR
Whirlpool KSCS25INWH02 REFRIGERATOR
Whirlpool KSCS25INWH03 REFRIGERATOR
Whirlpool KSCS25MSMS00 REFRIGERATOR
Whirlpool KSCS25MSMS01 REFRIGERATOR
Whirlpool KSCS25MTMK00 REFRIGERATOR
Whirlpool KSCS25MTMK01 REFRIGERATOR
Whirlpool KSCS25MTMS00 REFRIGERATOR
Whirlpool KSCS25MTMS01 REFRIGERATOR
Whirlpool KSCS25MVMK00 REFRIGERATOR
Whirlpool KSCS25MVMS00 REFRIGERATOR
Whirlpool KSCS25QFAL00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool KSCS25QFAL01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool KSCS25QFWH00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool KSCS25QFWH01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool KSCS27QFAL00 REFRIGERATOR
Whirlpool KSCS27QFAL01 REFRIGERATOR
Whirlpool KSCS27QFWH00 REFRIGERATOR
Whirlpool KSCS27QFWH01 REFRIGERATOR
KitchenAid KSF26C4XYB00 REFRIGERATOR
KitchenAid KSF26C4XYW00 REFRIGERATOR
KitchenAid KSF26C4XYY00 REFRIGERATOR
KitchenAid KSF26C6XYY00 REFRIGERATOR
KitchenAid KSF26C6XYY02 REFRIGERATOR
KitchenAid KSF26C7XYY00 REFRIGERATOR
KitchenAid KSF26C7XYY02 REFRIGERATOR
Whirlpool KSFS20QEAL0 SIDE BY SIDE REFRIGERATOR
Whirlpool KSFS20QEAL1 REFRIGERATOR
Whirlpool KSFS20QEBL0 SIDE BY SIDE REFRIGERATOR
Whirlpool KSFS20QEBL1 REFRIGERATOR
Whirlpool KSFS20QEWH0 SIDE BY SIDE REFRIGERATOR
Whirlpool KSFS20QEWH1 REFRIGERATOR
Whirlpool KSFS20QEWH2 SIDE-BY-SIDE REFRIGERATOR
Whirlpool KSFS25FJBL00 COUNTER DEPTH REFRIGERATOR
Whirlpool KSFS25FJBL01 COUNTER DEPTH REFRIGERATOR
Whirlpool KSFS25FJBT00 COUNTER DEPTH REFRIGERATOR
Whirlpool KSFS25FJBT01 COUNTER DEPTH REFRIGERATOR
  #2 (permalink)
Old 04-16-2011, 03:08 PM
Junior Member
Default
I solved the problem myself & here's the final resolution in case it may help someone else:
- I was correct that the evaporator fan was good (as my battery test had indicated).
- The microcptr had failed and was not sending a high enough voltage signal to the fan for it to start up. I replaced the orginal board #2221536 with the new board #4389211 and the fan operated correctly and my freezer/fridge are cool once again. The part was a little pricey ($217 + shipping) and hard to find, but it worked.
As an aside I had a very disappointing experience with Sears appliance repair. The short story is that when I thought the fan was good, and wasn't certain what was causing the problem, I called Sears. They came quickly (late the same day), diagnosed the problem, and told me it would take a week for them to get the part in and get back to install it. I said I'd do it myself the next morning and paid them $75+tax for the diagnosis. I then bought the $107+tax fan that they told me would fix the problem; it didn't. I called them and asked them to come back, which they did. But they then told me that they would not do further work since I had worked on the appliance and left.
After fixing the appliance, I called Sears, explained the situation, and asked for my $79.50 to be cerdited back since they had not olny misdiagnosed the problem, but it cost me an additional $118 for the wrong part. They declined to refund my money, I escalated, they declined again.
Needless to say Sears will remain on my naughty list for many many years to come.
Cheers,
John
  #3 (permalink)
Old 08-31-2011, 02:46 PM
Junior Member
watts120 is on a distinguished road
Default Give us a lead ... where did you order the part?
I tried to get the same part at my local app parts place and they said the part was discontinued. That I needed to get it rebuilt somewhere, but they gave me no leads....? Thanks.
Cheers,
John
  #4 (permalink)
Old 08-31-2011, 06:48 PM
Junior Member
Default
I too ran into the lack of availability of the part. At the time Whirlpool said that they were out of stock, but they would be manufacturing more at some point in the future (undefined). I found one at All Brand Appliance Parts. Their Havertown, PA store ordered one from their distribution center in Allentown, PA. At the time I believe that was the last one that they had in stock.
I believe that are companies that repair faulty boards (for almost the cost of a new one), but of course that could take some time to turn around. I found this one on the web but have no experience with them and am not endorsing them in any way: Repair and Return Refrigerator Control Boards [Refrigerator Repair and Return B] - $199.99 : Appliance Parts from Midwest Appliance Parts, Appliance Part Service, Chicago, Water Filters, Appliance Parts Chicago
Sorrythat I could not be of more help.
John
  #5 (permalink)
Old 12-12-2012, 10:03 PM
Junior Member
whiny is on a distinguished road
Default
Hi John,
I just registered to post a 'thank-you' to you. I found this thread after my (exact) same model of fridge exhibited the same symptoms. Unlike you, I went ahead and replaced the evaporator motor - assuming the fridge lasts years, I'm ok with this mistake.
The part was incredibly hard to find - actually your posted source was able to get me another "last one". They shipped it overnight to Vancouver - it was expensive, but I like this fridge, and it's a fraction of the cost of replacement - the next option should one be unable to find this board.
Anyhow, thank you for leading me quickly to the answer I needed. The time you took to explain your situation and the steps you took were so helpful to me and likely many others. This is what makes the internet great.
Best Regards,
Nate
  #6 (permalink)
Old 08-17-2013, 11:35 AM
Junior Member
jfarar is on a distinguished road
Default Whirlpool GC5SHGXKS00 Control Board and Evaporator Fan do not work
Thank you very much for your posts - I had the same problem!
I found a great electronic board repair shop in Austin, Texas - Fix Your Board (see web site) . They were able to repair my control board, Whirlpool 2221536, in one day! They were GREAT to work with!
I also found a PDF that walks you through this refrigerator:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7df852a21798567e85256b580067aa82/$FILE/8178066A.pdf
Sears has a web site that has all the parts diagrams for this refrigerator.
Thanks again... Jeff
  #7 (permalink)
Old 11-02-2013, 08:25 PM
Junior Member
iefoaix is on a distinguished road
Smile questions on refrigerator evaporator fan
I have questions on the original post:
I pulled the evaporator fan from the freezer and using a 9 volt battery put 9v across the yellow and white as well as the red and white terminals and the fan started to spin immediately.
How did you do this exactly: put the battery's positive to the
white and battery's negative to the yellow AND red?
I also have the following two failed tests:
Why do you say that Step 05 makes sense indicating it is not a problem?
Also my step 07 turns red initially and then immediately turns green.
I have also additional questions:
IF the voltage to the evaporator fan motor has the correct voltage:
the white to red is 12v, and the white to yellow is 8v, and the
fan does not turn, this means with 100% assurance that the fan is
bad?
And is that possible to use a multimeter to determine if the fan is
good or bad: what ohms need to be for what wires? Is there a diode
inside the motor? Why there are 4 wires, is there a wiring diagram for
the motor?
  #8 (permalink)
Old 11-02-2013, 10:00 PM
Junior Member
Default
Hello, the long story short is that the evaporator fan is okay. The mother board is bad. You need to send it to fixmyboard.com! If you wish to call me you can. My # is 210.913.1142
  #9 (permalink)
Old 11-17-2013, 02:32 PM
Junior Member
Default
To answer my own questions.
(1) How to test the fan. Connect a 9v battery positive to
red wire as well as the yellow wire, and connect the battery
negative to the white wire, the fan should run.
(2) Why step 05 was also red indicating "VC Compressor OFF,
waiting for min off delay"? You need to wait for 7 minutes
then the compressor will be turned on, and then the light will
turn green.
Also you need to measure the voltages to the fan while the fan
is connected (by using an extension wires and cut the skin of
the extension wires). In my case, the voltages are correct while
disconnected from the evaporator fan motor, but the voltage dropped
when connected. The problem is fixed by replacing the main
electronic control board.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Replacement in refrigerator Tebos Refrigerator & Freezer Repair 1 01-23-2014 12:42 PM
Evaporator Fan Blade not turning WendyLew Refrigerator & Freezer Repair 13 07-14-2010 12:57 PM
New motherboard not turning on compressor or evaporator fan jamievbva Refrigerator & Freezer Repair 0 11-27-2009 03:55 PM
LG Refrigerator Evaporator Fan Access amadeolr Refrigerator & Freezer Repair 1 02-09-2009 05:35 AM
refrigerator evaporator Bill K Refrigerator & Freezer Repair 0 04-06-2008 02:48 PM
