Discuss
Can't get temperature settings to stay
 in
Refrigerator & Freezer Repair
I cannot get the temperature settings to stay low on the fridge side of the Arctica unit It jumps up
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Can't get temperature settings to stay
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-30-2007, 11:49 AM
jacchiro jacchiro is offline
Junior Member
jacchiro is on a distinguished road
Default Can't get temperature settings to stay
Model Number: PSS27SGNA BS   Brand: GE   Age: 1 - 5 years
I cannot get the temperature settings to stay low on the fridge side of the Arctica unit It jumps up to 49 degrees and rising by itself. How do i get the setting to stay at 36 degrees or so or what should i do now since it is getting very warm. The freezer side seems ok and is at o degrees.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-31-2007, 02:57 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull freezer back panel and check frost pattern and post results. If totally frozen, thaw out with a hair dryer and check defrost heater and thermostat while still cold.
If ok, check the damper door in the refrigerator upper panel, if door jammed shut,unplug unit and jam door 1/2 open. If the damper door was jammed shut, order a new one.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't stay powered on karlkauai Dryer Repair 2 12-09-2007 03:49 PM
Sears Range - Bake won't stay ignited f-klein@sbcglobal.net Oven Repair (including Ranges and Cooktops) 0 10-25-2007 12:54 PM
FF temperature control Jesus Gutierrez Refrigerator & Freezer Repair 0 10-08-2007 07:54 PM
Maytag dryer won't stay running Schoolmom3 Dryer Repair 1 08-12-2007 01:59 AM
2nd post - Dryer won't stay running Schoolmom3 Dryer Repair 0 08-11-2007 10:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
