Discuss
Need to test thermostat
 in
Refrigerator & Freezer Repair
My freezer has iced up twice and worked again after we removed the back panel and allowed it to melt.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need to test thermostat
  #1 (permalink)
Old 04-13-2011, 09:52 AM
Junior Member
vwslinda@yahoo.com is on a distinguished road
Default Need to test thermostat
Model Number: MSD2356AEW   Brand: Maytag   Age: More than 10 years
My freezer has iced up twice and worked again after we removed the back panel and allowed it to melt. Everything I see on this site says to check the thermostat and heater (which seem to be the defrost assembly) and if they are fine, the defrost control board needs to be replaced. I have a digital multimeter. How do I test the defrost assembly?
Related Models
Maytag MSD2356AEW REF - SXS/I&W
Maytag MSD2357HEB REF - SXS/I&W
Maytag MSD2357HEQ REF - SXS/I&W
Maytag MSD2357HES REF - SXS/I&W
Maytag MSD2357HEW REF - SXS/I&W
Maytag MSD2359KEB REF - SXS/I&W
Maytag MSD2359KEQ REF - SXS/I&W
Maytag MSD2359KES REF - SXS/I&W
Maytag MSD2359KEW REF - SXS/I&W
Maytag MSD2422GRQ REF - SXS/I&W
Maytag MSD2422GRW REF - SXS/I&W
Maytag MSD2432GRQ REF - SXS/I&W
Maytag MSD2432GRW REF - SXS/I&W
Maytag MSD2433HEW REF - SXS/I&W
Maytag MSD2434GEQ REF - SXS/I&W
Maytag MSD2434GEW REF - SXS/I&W
Maytag MSD2436GRQ REF - SXS/I&W
Maytag MSD2436GRW REF - SXS/I&W
Maytag MSD2445GRQ REF - SXS/I&W
Maytag MSD2445GRW REF - SXS/I&W
Maytag MSD2448DRQ REF - SXS/I&W
Maytag MSD2448DRW REF - SXS/I&W
Maytag MSD2454FRQ REF - SXS/I&W
Maytag MSD2454FRW REF - SXS/I&W
Maytag MSD2454GRQ REF - SXS/I&W
Maytag MSD2454GRW REF - SXS/I&W
Maytag MSD2456DEB REF - SXS/I&W
Maytag MSD2456DEQ REF - SXS/I&W
Maytag MSD2456DEW REF - SXS/I&W
Maytag MSD2456GEB REF - SXS/I&W
Maytag MSD2456GEQ REF - SXS/I&W
Maytag MSD2456GEW REF - SXS/I&W
Maytag MSD2458GEB REF - SXS/I&W
Maytag MSD2458GEQ REF - SXS/I&W
Maytag MSD2458GEW REF - SXS/I&W
Maytag MSD2542VEB00 REFRIGERATOR
Maytag MSD2542VEB01 REFRIGERATOR
Maytag MSD2542VES00 REFRIGERATOR
Maytag MSD2542VES01 REFRIGERATOR
Maytag MSD2542VEU00 REFRIGERATOR
Maytag MSD2542VEU01 REFRIGERATOR
Maytag MSD2542VEW00 REFRIGERATOR
Maytag MSD2542VEW01 REFRIGERATOR
Maytag MSD2543ARA REF - SXS/I&W
Maytag MSD2543ARW REF - SXS/I&W
Maytag MSD2550VEB00 REFRIGERATOR
Maytag MSD2550VEB01 REFRIGERATOR
Maytag MSD2550VES00 REFRIGERATOR
Maytag MSD2550VES01 REFRIGERATOR
Maytag MSD2550VEU00 REFRIGERATOR
Maytag MSD2550VEU01 REFRIGERATOR
Maytag MSD2550VEW00 REFRIGERATOR
Maytag MSD2550VEW01 REFRIGERATOR
Maytag MSD2552VEA00 REFRIGERATOR
Maytag MSD2552VEA01 REFRIGERATOR
Maytag MSD2552VEB00 REFRIGERATOR
Maytag MSD2552VEB01 REFRIGERATOR
Maytag MSD2552VEW00 REFRIGERATOR
Maytag MSD2552VEW01 REFRIGERATOR
Maytag MSD2552VEY00 REFRIGERATOR
Maytag MSD2552VEY01 REFRIGERATOR
Maytag MSD2553WEB00 REFRIGERATOR
Maytag MSD2553WEB01 REFRIGERATOR
Maytag MSD2553WEM00 REFRIGERATOR
Maytag MSD2553WEM01 REFRIGERATOR
Maytag MSD2553WEW00 REFRIGERATOR
Maytag MSD2553WEW01 REFRIGERATOR
Maytag MSD2554ARA REF - SXS/I&W
Maytag MSD2554ARW REF - SXS/I&W
Maytag MSD2554DRA REF - SXS/I&W
Maytag MSD2554DRW REF - SXS/I&W
Maytag MSD2554FRA REF - SXS/I&W
Maytag MSD2554FRW REF - SXS/I&W
Maytag MSD2554VEA00 REFRIGERATOR
Maytag MSD2554VEA01 REFRIGERATOR
Maytag MSD2554VEB00 REFRIGERATOR
Maytag MSD2554VEB01 REFRIGERATOR
Maytag MSD2554VEQ00 REFRIGERATOR
Maytag MSD2554VEQ01 REFRIGERATOR
Maytag MSD2554VEW00 REFRIGERATOR
Maytag MSD2554VEW01 REFRIGERATOR
Maytag MSD2554VEY00 REFRIGERATOR
Maytag MSD2554VEY01 REFRIGERATOR
Maytag MSD2555DRA REF - SXS/I&W
Maytag MSD2555DRW REF - SXS/I&W
Maytag MSD2556AEA REF - SXS/I&W
Maytag MSD2556AEB REF - SXS/I&W
Maytag MSD2556AEW REF - SXS/I&W
Maytag MSD2559XEB00 REFRIGERATOR
Maytag MSD2559XEM00 REFRIGERATOR
Maytag MSD2559XEW00 REFRIGERATOR
Maytag MSD2572VEB00 REFRIGERATOR
Maytag MSD2572VEB01 REFRIGERATOR
Maytag MSD2572VES00 REFRIGERATOR
Maytag MSD2572VES01 REFRIGERATOR
Maytag MSD2572VEU00 REFRIGERATOR
Maytag MSD2572VEU01 REFRIGERATOR
Maytag MSD2572VEW00 REFRIGERATOR
Maytag MSD2572VEW01 REFRIGERATOR
Maytag MSD2573VEB00 REFRIGERATOR
Maytag MSD2573VEW00 REFRIGERATOR
Maytag MSD2574VEA00 REFRIGERATOR
Maytag MSD2574VEA10 REFRIGERATOR
Maytag MSD2574VEB00 REFRIGERATOR
Maytag MSD2574VEB10 REFRIGERATOR
Maytag MSD2574VEM00 REFRIGERATOR
Maytag MSD2574VEM10 REFRIGERATOR
Maytag MSD2574VEQ00 REFRIGERATOR
Maytag MSD2574VEQ10 REFRIGERATOR
Maytag MSD2574VEW00 REFRIGERATOR
Maytag MSD2574VEW10 REFRIGERATOR
Maytag MSD2576VEA00 REFRIGERATOR
Maytag MSD2576VEB00 REFRIGERATOR
Maytag MSD2576VEM00 REFRIGERATOR
Maytag MSD2576VEW00 REFRIGERATOR
Maytag MSD2578VEA00 REFRIGERATOR
Maytag MSD2578VEB00 REFRIGERATOR
Maytag MSD2578VEM00 REFRIGERATOR
Maytag MSD2578VEW00 REFRIGERATOR
Maytag MSD2641KEB REF - SXS/I&W
  #2 (permalink)
Old 04-13-2011, 12:18 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MSD2356AEW REF - SXS/I&W | AppliancePartsPros.com
Defrost heater with thermostat is Item 12 in Section 4.
The defrost thermostat is wired in series with the heater so you measure them both at the same time.
You should have 3 wires at the plug.
One is a defrost side, one is the heater side and one comes from the connection between the two. See the wiring diagram.
The thermostat is 0 ohms when frozen and the heaters are usually around 20 ohms.
Use a 200 ohm meter scale.
The defrost thermostat must be frozen for it to be closed so you will have to hold it's face on an ice cube to freeze it.
If the defrost thermostat is bulged or deformed it needs replacing even if it measures good.
__________________
  #3 (permalink)
Old 04-13-2011, 08:02 PM
Junior Member
Default test thermostat
This is wonderful information. The only thing I don't know is how to hook up the meter. Do I have to detach a wire or just hook it to the prongs on the plug? Thank you.
  #4 (permalink)
Old 04-14-2011, 02:33 AM
Senior Expert
APP Volunteer
Default
Yes.
Be sure the unit is unplugged whjen measuring ohms.
Following is my little blurb on meters.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How 2 test defrost thermostat mercuriojj Refrigerator & Freezer Repair 3 02-24-2011 06:34 PM
How to test a thermostat? mentch171 Refrigerator & Freezer Repair 10 12-11-2010 01:36 AM
How to test a thermostat ayersl Dryer Repair 6 08-25-2009 06:52 AM
How to test & change overn Thermostat stevebarlow Oven Repair (including Ranges and Cooktops) 1 07-11-2009 02:24 PM
test a cold control thermostat moose49304 Refrigerator & Freezer Repair 0 01-14-2008 02:19 PM
