Discuss
Ice Maker works but does not dispense ice in door
 in
Refrigerator & Freezer Repair
Ice Maker is working but will not dispense ice from door. What is wrong?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker works but does not dispense ice in door
  #1 (permalink)
Old 04-13-2011, 08:32 AM
Junior Member
RAMJFAUE is on a distinguished road
Default Ice Maker works but does not dispense ice in door
Brand: Kitchen Aid   Age: 5 - 10 years
  #2 (permalink)
Old 04-14-2011, 08:32 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
quote=RAMJFAUE;406620]Ice Maker is working but will not dispense ice from door. What is wrong?[/quote]
RAM,
Several possibilities, bad dispenser switch, auger motor, etc.
Does the water dispenser work ?
A model number will help, so we can be more efficient in assisting you.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-02-2011, 02:48 PM
Junior Member
Default
Quote:
RAM,
Thanks,
[/quote]
The model number is KSBS25FKBT00. The water dispenser does work. The light will not come on and the ise will not come out as a cube or crushed.
  #4 (permalink)
Old 05-03-2011, 06:50 AM
Senior Expert
Default
Quote:
Originally Posted by RAMJFAUE View Post
RAM,
Thanks,
The model number is KSBS25FKBT00. The water dispenser does work. The light will not come on and the ise will not come out as a cube or crushed.[/quote]
Ram,
You want to start at the freezer door hinge,on the bottom, check the wiring harness connections for loose and possible shorted wires.
From there you'll need to remove the dispenser front panel and check the switches and wiring for loose connections and the switches, for the ice dispenser and cavity light.
You'll need a few basic handtools
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
* Use a flatblade screwdriver and a pad to remove the panel, use the pad between the facade panel and the door panel to reduce damage to the panel *
4
. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly
18. Reassemble in reverse order.
Good Luck
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 05-03-2011, 12:11 PM
Junior Member
Default
Thank you. I hope I find a loose wire.
  #6 (permalink)
Old 05-05-2011, 07:18 AM
Senior Expert
Default
Ram,
You're welcome,
A loose wire would be nice, let's hope .
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Won't Dispense Ice Maker Works PAULUS1024 Refrigerator & Freezer Repair 14 02-23-2013 07:38 PM
Ice maker works fine, but doesn't dispense colleen134 Refrigerator & Freezer Repair 3 07-23-2010 11:04 PM
Ice maker works but won't dispense donniem Refrigerator & Freezer Repair 1 09-01-2009 05:35 PM
Ice maker works. Won't dispense cubes or crushed ice Derjimmer Refrigerator & Freezer Repair 32 08-11-2008 11:36 AM
Ice maker won't dispense ice, water works fine..... pani Refrigerator & Freezer Repair 5 07-25-2008 03:06 PM
