Discuss
refrigerator and freezer not cooling properly
 in
Refrigerator & Freezer Repair
Refrigerator side and freezer side are not cooling properly, and noticed ice buildup on freezer side at the back. Since
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator and freezer not cooling properly
  #1 (permalink)
Old 04-13-2011, 07:18 AM
Junior Member
Gman60 is on a distinguished road
Default refrigerator and freezer not cooling properly
Model Number: 2538685894   Brand: Kenmore   Age: More than 10 years
Since this unit is 13 yrs. old, is it worth repairing? What do you think is the problem?
Thank you.
Related Models
Kenmore 2538705080 AIR CONDITIONER
Kenmore 2538705090 AIR CONDITIONER
Kenmore 2538706110 AIR CONDITIONER
Kenmore 2538706111 AIR CONDITIONER
Kenmore 2538710750 AIR CONDITIONER
Kenmore 2538712580 AIR CONDITIONER
Kenmore 2538712581 AIR CONDITIONER
Kenmore 2538712582 AIR CONDITIONER
Kenmore 2538712583 AIR CONDITIONER
Kenmore 2538712584 AIR CONDITIONER
Kenmore 2538712585 AIR CONDITIONER
Kenmore 2538712586 AIR CONDITIONER
Kenmore 2538712587 AIR CONDITIONER
Kenmore 2538712588 AIR CONDITIONER
Kenmore 2538721650 AIR CONDITIONER
Kenmore 2538740652 WINDOW AIR CONDITIONER
Kenmore 2538740655 AIR CONDITIONER
Kenmore 2538740656 AIR CONDITIONER
Kenmore 2538740664 AIR CONDITIONER
Kenmore 2538740665 AIR CONDITIONER
Kenmore 2538740667 ROOM AIR CONDITIONER
Kenmore 2538750891 WINDOW AIR CONDITIONER
Kenmore 2538750991 WINDOW AIR CONDITIONER
Kenmore 2538751211 WINDOW AIR CONDITIONER
Kenmore 2538751212 WINDOW AIR CONDITIONER
Kenmore 2538751461 WINDOW AIR CONDITIONER
Kenmore 2538753062 WINDOW AIR CONDITIONER
Kenmore 2538753065 ROOM AIR CONDITIONER
Kenmore 2538753101 WINDOW AIR CONDITIONER
Kenmore 2538753102 WINDOW AIR CONDITIONER
Kenmore 2538754112 WINDOW AIR CONDITIONER
Kenmore 2538761290 AIR CONDITIONER
Kenmore 2538761291 WINDOW AIR CONDITIONER
Kenmore 2538761640 WINDOW AIR CONDITIONER
Kenmore 2538761850 WINDOW AIR CONDITIONER
Kenmore 2538765071 ROOM AIR CONDITIONER
Kenmore 2538765072 ROOM AIR CONDITIONER
Kenmore 2538765074 AIR CONDITIONER
Kenmore 2538765082 AIR CONDITIONER
Kenmore 2538765084 AIR CONDITIONER
Kenmore 2538771062 AIR CONDITIONER
Kenmore 2538771063 AIR CONDITIONER
Kenmore 2538771065 ROOM AIR CONDITIONER
Kenmore 2538771066 ROOM AIR CONDITIONER
Kenmore 2538771290 WINDOW AIR CONDITIONER
Kenmore 2538771390 WINDOW AIR CONDITIONER
Kenmore 2538780840 AIR CONDITIONER
Kenmore 2538780841 ROOM AIR CONDITIONER
Kenmore 2538780891 AIR CONDITIONER
Kenmore 2538780893 AIR CONDITIONER
Kenmore 2538780990 AIR CONDITIONER
Kenmore 2538781210 AIR CONDITIONER
Kenmore 2538781291 AIR CONDITIONER
Kenmore 2538781391 AIR CONDITIONER
Kenmore 2538781460 AIR CONDITIONER
Kenmore 2538781461 AIR CONDITIONER
Kenmore 2538781857 AIR CONDITIONER
Kenmore 2538782591 AIR CONDITIONER
Kenmore 2538782592 AIR CONDITIONER
Kenmore 2538783080 ROOM AIR CONDITIONER
Kenmore 2538783081 ROOM AIR CONDITIONER
Kenmore 2538783110 AIR CONDITIONER
Kenmore 2538783111 ROOM AIR CONDITIONER
Kenmore 2538784110 AIR CONDITIONER
Kenmore 2538784111 AIR CONDITIONER
Kenmore 2538785101 AIR CONDITIONER
Kenmore 2538785102 AIR CONDITIONER
Kenmore 2538790750 KENMORE ROOM AIR COND.
Kenmore 2538791290 REFRIGERATOR
Kenmore 2538791292 REFRIGERATOR
Kenmore 2538791293 AIR CONDITIONER
Kenmore 2538791460 KENMORE ROOM AIR CONDITIONER
Kenmore 2538791461 KENMORE ROOM AIR CONDITIONER
Kenmore 2538791462 AIR CONDITIONER
Kenmore 2538791830 AIR CONDITIONER
Kenmore 2538791831 AIR CONDITIONER
Kenmore 2538791832 AIR CONDITIONER
Kenmore 2538791833 AIR CONDITIONER
Kenmore 2538794110 AIR CONDITIONER
Kenmore 2538795110 AIR CONDITIONER
Kenmore 2538796000 REFRIGERATOR
Kenmore 2538796001 REFRIGERATOR
Kenmore 2538796010 REFRIGERATOR
Kenmore 2538796011 REFRIGERATOR
Kenmore 2538796020 REFRIGERATOR
Kenmore 2538796021 REFRIGERATOR
Kenmore 2538796060 REFRIGERATOR
Kenmore 2538796061 REFRIGERATOR
Kenmore 2538796080 REFRIGERATOR
Kenmore 2538796081 REFRIGERATOR
Kenmore 2538796090 REFRIGERATOR
Kenmore 2538796091 REFRIGERATOR
Kenmore 2538796200 REFRIGERATOR
Kenmore 2538796201 REFRIGERATOR
Kenmore 2538796202 REFRIGERATOR
Kenmore 2538796203 REFRIGERATOR
Kenmore 2538796210 REFRIGERATOR
Kenmore 2538796211 REFRIGERATOR
Kenmore 2538796212 REFRIGERATOR
Kenmore 2538796213 REFRIGERATOR
Kenmore 2538796220 REFRIGERATOR
Kenmore 2538796221 REFRIGERATOR
Kenmore 2538796222 REFRIGERATOR
Kenmore 2538796223 REFRIGERATOR
Kenmore 2538796260 REFRIGERATOR
Kenmore 2538796261 REFRIGERATOR
Kenmore 2538796262 REFRIGERATOR
Kenmore 2538796263 REFRIGERATOR
Kenmore 2538796280 REFRIGERATOR
Kenmore 2538796281 REFRIGERATOR
Kenmore 2538796282 REFRIGERATOR
Kenmore 2538796283 REFRIGERATOR
Kenmore 2538796290 REFRIGERATOR
Kenmore 2538796291 REFRIGERATOR
Kenmore 2538796292 REFRIGERATOR
Kenmore 2538796293 REFRIGERATOR
Jenn-Air 2539 WALLOVEN- STD ELE
Kenmore 2539100180 CHEST FREEZER
Kenmore 2539103010 CHEST FREEZER
Kenmore 2539103011 CHEST FREEZER
  #2 (permalink)
Old 04-13-2011, 12:36 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any info on the given model number. Tried here, the sears site and the Frigidaire site.
Please check it.
If this is a non USA model info may not be available.
Try to see if it uses a defrost timer or an adaptive defrost board.
Timers may be located in the machine compartment under the unit often at the front.
They also mount them in the control console at the to[p of the fresh food section. There is often a hole to allow you to turn the cam with a screw driver.
The cam only turns in one direction.
For a timer system
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Also here is a good link with basic fridge repair info which should come in handy. It has how to force a defrost with an adaptive board on most Frigidaires who actually made your unit. See #30.
http://www.applianceaid.com/refrigerator.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Refrigerator Not Cooling Properly Mazhar1 Refrigerator & Freezer Repair 1 03-06-2011 03:22 AM
refrigerator not cooling properly cwp03 Refrigerator & Freezer Repair 5 04-13-2010 12:35 PM
Neither freezer nor refrigerator cooling properly lamartin Refrigerator & Freezer Repair 3 03-18-2009 04:25 AM
refrigerator not cooling or freezing properly. Bill K Refrigerator & Freezer Repair 4 08-09-2008 09:06 AM
Refrigerator not cooling properly kjr56 Refrigerator & Freezer Repair 1 05-27-2008 07:58 PM
